Need help for radar connector for prime 2021
Discussion in 'Prime Technical Discussion' started by maxidream, Mar 24, 2022.
  1. maxidream
    maxidream Junior Member
    24
    usa
    2019 Prius Prime
    Hello
    Pls can someone help me
    I got accident and the wire take off from connector and i need plug in again but i don’t know which wire color correct.
    / DBD3F773-E334-46AC-AC9D-80EA68A76AF5.jpeg D8602C06-FB58-404A-AA4A-1BC6CD3813A8.jpeg
  2. Elektroingenieur
    2,515
    3,284
    Three Touring
    The Electrical Wiring Diagram (more info) gives the pinout for connector A2, Millimeter Wave Radar Sensor Assembly:
    Terminal 1: White/Black (SGND)
    Terminal 2: White (CA2L)
    Terminal 3: Green (CA2H)
    Terminal 4: (Not Used)
    Terminal 5: Black (CA1P)
    Terminal 6: White (CA1N)
    Terminal 7: (Not Used)
    Terminal 8: Light Green (IGB)​
    For each of the two CAN communication buses, the wires should be twisted pairs: CA1P with CA1N, and CA2H with CA2L.
    If there was enough damage to require repairs to the connector, you’ll probably also need to do the adjustment procedure for the sensor assembly itself, by the way; see the Repair Manual for details.
    Tideland Prius and maxidream like this.
  3. maxidream
    24
    usa
    2019 Prius Prime
    Great Thank u so much for help me
    Elektroingenieur likes this.
  4. Gokhan
    Gokhan Senior Member
    6,252
    2,484
    Paramount CA
    I would let the insurance handle this; otherwise, it will cost you a fortune (thousands of dollars) to have the sensors recalibrated.
  5. maxidream
    24
    usa
    2019 Prius Prime
    why insurance do this I fix it I bought connector from amazon $10 and i follow Elektroingenieur for info and it's work perfect.
