Need help identifying a random chirp
Discussion in 'Gen 4 Prius Main Forum' started by Carsonic, Jan 22, 2025.
  1. Carsonic
    Carsonic New Member
    Orlando, FL
    2022 Prius
    L Eco
    Our '22 L Eco will chirp - and this is not the lane edge proximity ding - at random times. When we're maintaining highway speed, when we're stopped, when we're ac- or decelerating. Very weird. Sounds like it's coming from the left half of the dash. Here is a video clip with dimmed road noise on either side of the chirp.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Hmmm....definitely something electronic beeping. Is it coming from behind the dash? Did you buy the car new? I'm wondering if someone installed some sort of device in there. There's nothing plugged into the OBD port under the steering wheel, is there? I'd, also, check the fuse boxes for anything plugged in. (That beep doesn't sound like any beep I've heard a Toyota make.)
    Carsonic likes this.
    52,396
    Could it be your phone?
  4. Optimus
    Optimus Member
    274
    25
    Doesn’t even resemble a topical Toyota noise. If you are able, crawl into the driver footwell looking up under the dash with a flashlight, and see if you see anything. I suspect something aftermarket.
  5. Carsonic
    Carsonic New Member
    Orlando, FL
    2022 Prius
    L Eco
    Thanks, I appreciate the response. I'll check there for sure.
    Definitely not my phone, but thanks.
    I'll definitely do this, thanks!
    #5 Carsonic, Mar 4, 2025
  6. Carsonic
    Carsonic New Member
    Orlando, FL
    2022 Prius
    L Eco
    Turned out you were right! It was a Geotab Go Fleet tracker.
    ColoradoBoo likes this.
  7. ColoradoBoo
    1,271
    879
    Glad you found it!
    A few years ago, I'd hear an annoying sound coming from the right/front side of my Tundra but not always...just as certain highway speeds....drove me nuts!
    The Tundra has a metal skid plate and not many plastic covers so I knew it wasn't that. Look all under the engine and around, nothing! Then, I was walking by the right, front tire and looked in there....some engineer at Toyota decided to put a little cloth cover over the outside of the suspension held on by three little plastic clips. Well, the cloth, on the front, had ripped and it would flap at certain speeds. I researched just buying a new cloth and clips but couldn't find anything so just removed it. (The other side, also, got ripped so it's now gone, too.)
    If anybody knows what they are called I'd appreciate it...would like to replace them. When searching Toyota parts, half the battle is finding what they call stuff!
  8. Mendel Leisk
    41,912
    Our home theatre amp does a sound much like that, when set to certain inputs, playing blue ray or dvd, phases of the moon. Get's worse as it heats up.
    Is it frequent enough dealership could replicate with a test drive? If it's an electronic component failing, that'd likely be warrantied.
    Except, what are they charging for a "diagno$tic" these days? Maybe it's time Toyota mothership started cracking down...
    #8 Mendel Leisk, May 20, 2025
