Need Help-my 06 Prius won't start
Discussion in 'Gen 2 Prius Technical Discussion' started by jodster, May 21, 2011.
  1. jodster
    jodster New Member
    My 2006 has 121000 miles and started acting strange in March. I drove it to the dealer and it died. After the dealer ran the diagnostics test they gave the code for "bad cell 5" and "replace battery". The dealer wanted way too much so I had the car towed home and installed a rebuilt battery this week (my car set for almost 2 months). After putting in new battery it wouldn't start due to the 12v battery being dead. So I replaced the 12 v battery and now it still will not start but all of the displays work. I am getting the red triangle, the check engine light and the "exclamation in the car" on the main display. I don't know if this has any bearing on the problem but I did find the dealer had removed one of my spark plugs and left in under the hood. I re-installed it before attempting to start to car. Does anyone have any advice or experience with a problem like this. Also, the water pump that has been recalled is still on my Prius and hasn't been replaced (would this effect the vehicle starting?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Since you replaced the battery, double, then triple check the orange HV battery connector. It is a twist snap and LOCK type connector. It looks like it is on or connected, but not most of the times. This will prevent starting.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    ^ Read this again, just in case you missed it the first time.
    Tom
  4. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Just curious, how much was the dealer asking for, and how much did you pay?
  5. bisco
    51,154
    where did you get the rebuilt battery?
  6. jodster
    jodster New Member
    Thanks, I will double check it again.
  7. jodster
    jodster New Member
    The dealer wanted $3111 for the battery. I purchased one for $1864 which includes $145 for shipping.
  8. jodster
    jodster New Member
    I purchased my rebuilt battery from Re-involt (taylor automotive).
  9. bisco
    51,154
    excellent.
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Contact Reinvolt!
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    No reply from the OP for over a week makes me guess that the orange HV connector was the problem and that he is now up and running. It would have been nice if the OP had of confirmed this for us though.
  12. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I agree! Hal
  13. andyprius
    2,212
    188
    Some op's don't realize that we are truly interested.
