Need help! Overheating problems.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sanch860, Mar 2, 2020.
  1. Sanch860
    Sanch860 New Member
    Groton, CT
    Hello,
    i just got a 2010 Prius with 208,000 miles about a week ago. Before I got the car they put a new coolant temperature sensor in since an engine light was coming up for it and it went away and everything was fine. A few days ago the engine light came on for PO177- Engine Coolant Temperature (ECT) Sensor Circuit Low Output Problem. The cars heat doesn’t work and only cold air comes out. I also noticed the coolant was low even thought they filled it up right before I got it. The High coolant temperature warning light comes up every time I accelerate a little hard or drive over 60mph and doesn’t go away until I let off the gas and let the car cruise for a while. I filled up the coolant yesterday and i didn’t see anything leaking but today it is back down again. Also I have an engine light for misfire on 2 &4 and right before I got the car they put new spark plugs in. Any advice on what I should do or what the problem could be? Thanks.
    52,363
    head gasket, can you return the car?
    pjksr02 likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Get your money back, the sooner the better. And never buy high mileage gen 3 prius.
  4. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    You were tricked into buying a car with a blown head gasket. I’m sorry this happened to you. Go back to the seller.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    And then do what?
  6. Borninblue
    233
    158
    Cleveland, Ohio
    if it was me I would give them the opportunity to make it right. If not, I punch them in the mouth and walk away with some satisfaction.
    Grit and bisco like this.
  7. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Since they did try to resolve the issue already, a right hook to the kisser is now recommended.
    Borninblue likes this.
  8. Mendel Leisk
    41,876
    If you keep the car, after doing the head gasket (assume that's the problem, a fairly safe bet), immediately clean the Exhaust Gas Recirculation circuit (all components), and the intake manifold (pay special attention to the EGR passages, one per port). And install an oil catch can.
