Need Help QUICK! MPG dropped BAD and high RPM!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by F8L, Apr 9, 2011.
  1. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    *edit* This an old thread.
    I'm on a 5hr trip to Arcata and since we started the car is running at 2500-3200 rpm trying to maintain 70 mph. Gas mileage instantaneous is 29-32 mpg and average is 35mpg. The hybrid system appears to be working, the brakes are not hot . The front brakes are cold! No obstructions in the intake that I can't see. No warning lights. The only recent change to the car was a headlight swap last night but I did it the easy way and didn't take anything apart. Scangauge tells me my average speed is anywhee from 0 to 137 for this tank. I filled up this morning and just used half a tank to go 154 miles. :(
    I'm driving so can't check this often so if Patrick or someone would be willing to call me it would be appreciated. :)
  2. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    :( Sorry to hear this, F8L.
    Hoping someone helps you out.
  3. uart
    uart Senior Member
    4,215
    1,201
    Australia
    How is your SOC holding up FL8? Does everything look normal there or are you getting low levels (like 2 purple for example).
    Are there any unusual wind condition or anything?
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Bummer dude. Sounds like the dreaded HV battery death. Just kidding, have no idea whats wrong. :)
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    When you say headlight swap do you mean a new bulb or do you mean the swap to HID lamps?
    I'm wondering if the 12v is the original (5 years old now?) and the extra load by changing the headlights has finished it off?
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    battery recal ?
    If F8L has a SG it might be worthwhile to also check the battery temp; I think that is one of the x-gauges.
  7. Patrick Wong
    18,200
    6,479
    My immediate thought is that the shift selector is in B, but I am sure that F8L would not make that error.
    My next thought is that the hybrid vehicle ECU may have a glitch in it so that the transaxle is performing as if B was selected. With that in mind, I suggest that F8L should disconnect the 12V battery for 5 minutes, then reconnect; after he reaches his destination. This allows all ECUs to power down and reset.
    If that doesn't help then a visit to a Toyota dealer would be worthwhile. Good luck.
  8. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I'm guessing if you are taking the 101 then you have a good stretch in the mountains, you may be reaching the limit of regen during some of the downhill sections.
    Unless you took the 5 north and before hooking west, you are still in the mountains before reaching your dest.
    Would it be worth it to check the oil dipstick, coolant levels, air filter, etc.?
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I really appreciate the help guys.
    I don't normally freak out about mpg but this is a really odd situation. Normally at 70 mph I see an average of 45 mpg with this 17" wheel/tire combo. In this case I was experiencing as low as 29 mpg instant while trying to maintain 70mph. RPM was i'll the 3000s. It was crazy because the was no wind and I was on very flat highway. Even trying to accelerate from a stop briskly but not aggressively it would rev up to 4k trying to get up to 40 mph.
    SOC was solid at 65-66%
    Scangauge buf was 45-60
    12v battery is an Optima and i've had the stereo off for a couple days so charge should be good.
    I only changed the HID bulbs last night. The 55w HID kit was installed weeks ago and mpg was good until today.
    Here is the variable. I swapped my 15s out to my 17s a few days ago. Mpg dropped from 51mpg avg. to about 46 mpg avg. on then same commute. I expected this as it always happens when I swap. This time the tires make a thumping sound at low speed like one is out of balance. I realize this is not good for mpg but for the last few days my mpg was normal for this combo. Until today that is.
    Now after I posted this thread, we started up the the mountain (Trinity wilderness area from Weaverville to Arcata) and by the time we got to our destination I was at 42 mpg avg. So climbing up and down the Coastal Range at high speed netted me better mpg than flat freeway (35mpg vs. 42).
    Could there be something going on with the tires all of a sudden? They are about 4 years old.
    InThe mean time i'm going to reset the battery as per Patrick's suggestion.
    Thanks again guys. I'm worried it is the transaxle.
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Good call. We took 5 because 101 is closed. From Davis to Weaverville is were the worst of this was happening.
    I checked the brakes pads, parking brake, air filter and induction, all engine plugs or connections, I wasn't in B mode, the car pulls slightly to the right but not bad enough to causes this. Oil level is perfect as well.
    When accelerating is feels almost like a slipping clutch in that it revs up much higher than it normally does.
  11. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    You need to check if one of the lug nuts is loose or something keeping one of the tires unbalanced.
  12. Mark57
    2,945
    2,737
    OK
    Use your scangage to verify this. It's an included monitor and will show your 12v batt voltage.
    Also, don't forget to remove your ph # back in the first post.;)
  13. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Did you run your headlights during the flat section in the central valley and then turn them off during the mountain driving when you achieved better mileage?
    If so that may be indicate something wrong with your HIDs. Run your headlights and check the ballasts to see if they are overheating.
  14. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I am wondering if rubber dry-rot, before it cracks, gets very hot when flexed? Can you check your side wall temps? Just by hand, carefully. If you cannot get your hand close to them, that could be it.
    Also, do the knuckle test on the brake disks/drums. They should not be hot. Does it roll nice downhill? Can you get into warp stealth?
    Have you had your inverter pump replaced per the service campaign? If the inverter is running hot, the car may be limiting the MG1 current to try to keep it cool. But, you should get a DTC on that, I guess. Still, lots of people drive around with bad inverter pumps, sucking 12 V amps, before the inverter overheats too. Check your 12 V current. What does a Prius 12 V current run at down the road? 2 amps?
    Just throwing out ideas here....
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Lug nuts are tight and wheels appear snug against the hubs
    While running the voltage reads 14v. And thanks for the reminder!
    I tried with headlights off and on for long periods with no change.
    The Tires and brakes were cool to the touch. The coolant pump was replaced in Dec as part off the recall. I can't warp stealth burn it is sometimes more difficult because these performance tires do not glide well. They never have.
  16. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Do you have dogs? Could the HV battery fan be clogged with fur/dirt?
  17. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Since a wheel swap was the most recent change to the car, that is the most suspicious aspect of this.
    I didn't see anyone mention tire pressure. Are the tires set to the pressure that you usually use? Many tires nowadays are directional: are yours directional, and are they pointing in the correct direction?
    Front brakes are cold so not the problem, but the rear drums tend to have more problems. Are both drums cold to the touch too?
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    NoDogs and the battery temp is good. :)
    Tires are at 52/50. Both drums were slightly warm but just barely.
    I tried the battery reset and around the block it seemed to be fine but once I hit the highway the problem was stilk evident. 65mph showed instantaneous of low 30 mpg. Grr
  19. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Checked the engine air filter lately?
  20. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Changed it 3 weeks ago. It is still clean.
    I 'mgoing to drive it home tomorrow and put the 15s back on to rule out the 17s and tires. I've never had this problem with them before though.
