Need help removing bug & tar cleaner from windshield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by co_prius_3, Jul 28, 2015.
  1. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I made the mistake of using a bug and tar remover on the windshield to remove bugs. It left a permanent coating that makes it hard to see when the Sun hits it. Any suggestions for cleaning products that won't scratch the glass? The windshield is a non-OEM replacement, not the factory original.
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    ISO-PROPYL (rubbing) alcohol to remove the pine-tar, then 0000 steel-wool, followed by Rain-X. (see threads passim, plus youtube video)
    There's a vid on youtube (…isn't there always!) of exactly how it's done!
  3. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    Thanks, I'll try that.
  4. Mendel Leisk
    38,718
    I do not know about the steel wool. Maybe ok, but try on inconsequential corner first.
    Maybe try automotive glass cleaner, the spray can bodyshop stuff?
  5. JC91006
    16,482
    8,399
    If you use anything that can scratch, make sure you coat the glass with Windex before you use it
  6. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    From what I've read, 0000 fine steel wool is safe on glass. Not 000, according to another thread.
    Here's a video that recommends using it dry before using a liquid cleaner.
    #6 co_prius_3, Jul 28, 2015
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Let me get this straight.
    At this point you're NOT removing any bugs or pine tar.
    What you are trying to remove is some coating or haze left over as a byproduct of using Bug and Tar remover?
    Good Luck, I'm hoping the Bug and Tar remover didn't do some irreversible damage to the glass.
    Let us know how it goes.
  8. Den49
    Den49 Member
    498
    268
    Maryland
    Have you tried dishwashing soap, i.e. Dawn?
  9. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Kerosene removes road tars and bugs. Ammonia takes car of the rest.
  10. Mendel Leisk
    38,718
    I used a kerosene moistened rag with a dollop of car polish, for tree pitch, worked best of all the things I tried.
    Still, hard to tell what's going on with this windshield.
  11. JC91006
    16,482
    8,399
    did you try to just wash the windshield with some dish soap? Also are you sure the glare is not coming from "interior" part of the windshield? I know my windshield needs to be wiped from the "inside". You can clean the outside all you want....it won't make improvements to the inside
  12. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    You can also try using a clay bar...
  13. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I tried the 0000 steel wool. It got close to 90% of the residue off without scratching AFAICT. I think it got less effective the more it picked up, so a second treatment might get the rest. I used it on the inside too, since that seemed to have a film. Now the windshield is clear even in direct sunlight.
  14. orenji
    orenji Senior Member
    5,884
    3,486
    Who Knew! Steel Wool would clean glass. I always use industrial razor blades and Ivory dish soap deluded with water in a spray bottle to get really clean glass.
  15. CollinPark
    CollinPark Junior Member
    Philadelphia
    have you driven in the rain after cleaning with steel wool?
    to the naked eye it may appear that there is no real difference, but when you scratch the surface, you introduce a change in the surface roughness, which basically changes the wetting properties of the glass.
    most car glass is finished with a hydrophobic post-treatment and if that's damaged driving in the rain will be a less pleasant experience. (there are spray on products if you accidentally removed it)
    I'm curious to know whether 0000 grade steel is good on that front
  16. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ugh, I would have started with car wax and followed up with Invisible Glass
  17. qdllc
    qdllc Senior Member
    1,370
    399
    Car detailer gave my mom this simple recipe.
    A shot of dish soap. A splatter of white vinegar. Hot water. Use one microfiber towel to apply and scrub. Use another one to dry glass.
    wjtracy likes this.
  18. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    yeah microfiber is good idea too
