Need help swapping 2005 XM for Sirius
Discussion in 'Gen 2 Prius Audio and Electronics' started by dsss, Nov 21, 2008.
  1. dsss
    dsss New Member
    16
    I have a 2005 Prius with a "Factory" XM install. I used the CoastalTech Kit which I believe was just an older XM tuner, antenna, plugs, etc... I want to put in Sirius instead and was wondering if I could simply purchase an appropriate Sirius tuner and antenna and swap that with my existing XM tuner? Any recommendations on the easiest way to do that and what parts to look for?
    Thanks very much for any help you could offer.
  2. rwa46
    rwa46 Pilot
    38
    south central Texas
    xm and sirius are the same now. why do you want to swap?
  3. dsss
    dsss New Member
    16
    They actually aren't exactly the same yet (premium services like MLB and NFL are still not integrated), but that aside, I have a lifetime sub with sirius and want to use it in my prius instead of paying for XM at this point.
  4. rwa46
    rwa46 Pilot
    38
    south central Texas
    i have installed sirius not xm so haven't seen both plugs. i would pull out back seat and see the plug end for the xm and then compare with the sirius unit. if the same you are set if not will need new one. also if you have lifetime subscription with one you how have it with both (yes no) i would call and ask before doing anything.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You can get MLB and NFL now on both Sirius and XM.
    But seriously, I think it's worth some phone calls and trying to escalate the calls higher up the chain of command to see if you can convert your Sirius lifetime sub to a Sirius/XM lifetime that would let you keep the XM tuner installed.
    Beyond that/failing that, I'd be surprised if you can just swap out the tuner without changing cables...maybe I'm wrong, but I suspect they have unique tuner-end plugs...and aren't the antenae different too?
