Need Help SWI-JACK JVC Steering Wheel Controls
Discussion in 'Gen 3 Prius Audio and Electronics' started by mee081224, Jul 25, 2011.
  1. mee081224
    mee081224 New Member
    193
    Tampa, Florida
    Here is a video of my connections. Everything lights up, so you would think I have made all correct connections. I used the green blue brown transitor.
    I have my SWI Jack on setting 2, it is in mode8.
    Any help would be appreciated.
    Here is a video
  2. mee081224
    193
    Tampa, Florida
    Anyone? Anyone? Bueler? I can take still shots. Anyone?
  3. rrolff
    rrolff Prius Surgeon
    1,610
    245
    So Cal
    Ummm - maybe call PAC???????? They do have very good customer service...
  4. mee081224
    193
    Tampa, Florida
    Seriously I didnt think of that, and I work in IT. lol. I will do it on the way home. Ill let you know what I find out.
    Hey Rrolff, I sent you a pm about Cam install. Is it a simple get it mounted, slip it through the boot, through the rooftop to the front pillars down into the hu?
  5. mee081224
    193
    Tampa, Florida
    Wow I am a jack nice person, is this seriously how you program it?
    I was trying to do the first task (volume up) and then waiting for a light to come on. Uggh.
  6. vidoprof
    vidoprof New Member
    136
    Tampa, FL
  7. mee081224
    193
    Tampa, Florida
    Not yet, I saw the video, as soon as I get home work I will try it out. Hopefully it works.
    This and the cam is the only thing not installed yet. And the subs/amp but that is for a later date.
    Did you get your car done yet?
  8. rrolff
    1,610
    245
    So Cal
    It's a pain in the butt to fish the cable through - search here to find instructions and pics...
    The things I would take note of - grind the yellow RCA cable (plastic surround) down around its case to make it smaller and more easy to fish. Use random lube to help it slide through - I also attached it to a coat hanger (duct tape) to help guide it.
    Lastly, I cut a tiny slit in the boot - like 1/4" to allow me to poke and probe to move it the last 1/2 inch... You'll likely need an added 8' of yellow cable in addition to the 25' that come with the cams (from memory)...
  9. mee081224
    193
    Tampa, Florida
    Thanks for the info. I had time to test the cam before I installed the HU. So now all I have to do is mount it and run the wiring. This will be a weekend project.
    On a side note I fried my swi jack unit last night, so i order a replacment. I am going to start from scratch and follow PAC's instructions instead of looking at diagrams. I think I misinterpreted some symbols
  10. mee081224
    193
    Tampa, Florida
    In case someone wants to know. It turned out my unit was defective, got a new one and it works. The only sucky part is that there was no preset down. So I am using seek up and seek down. Does anyone else have a different setup with their PAC?
Loading...
