Need help to put the glove box back
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyolover, Jan 5, 2011.
  1. toyolover
    toyolover Member
    423
    60
    toronto, canada
    I have just removed the lower glove box in my Gen3 in order to replace the cabin filter. While taking out the glove box, the plastic hydraulic support on the right fell off from its side support. Now I am having problem trying to figure out where it suppose to go. Picture 1 is, I believe, where the hydraulic support goes on the side of the glove box. Picture 2 is the side of the compartment. I have a red circle in this picture but when I put the support back, it doesn't seem to be in the correction position as it will come off when I close the glove box.
    Can someone help me by posting a picture of the correct installation?
    Your help is very much appreciated.
  2. spiderman
    spiderman wretched
    7,540
    1,528
    Alaska
    Be careful! I broke my latches because the box went in incorrectly and I had to yank it out.
    The dampener is fun. I ended up wedging some wood (between the slots) to help keep it on while assembling.
    Also iirc the large end goes up.
  3. stream
    stream Senior Member
    2,977
    451
    Long Island, NY
    Before removing the glove box, you're supposed to slide the damper off the glove box (see p. 449 of owners manual), and the damper stays attached to the car (not the glove box).
    Slide the damper off the glove box, then insert the part you circled in red into the hole on the left of the damper assembly in your picture.
  4. toyolover
    toyolover Member
    423
    60
    toronto, canada
    Yes, I did slide off the damper from the glove box but at the same time, the damper came off. Now I am not too sure where it was attached to before.
    First, I am assuming I have the damper put back on the glove box without turning it upside down (as shown in my first picture).
    Can you be specific to say, from the two pictures below, A goes to C or B goes to C?
    I tried it both ways but it seems that when I close the glove box, the damper will come off from the C point.
    Thanks.
  5. spiderman
    spiderman wretched
    7,540
    1,528
    Alaska
    A should go attach to C. Put the box in and draw it up to the damper and attach.
  6. toyolover
    toyolover Member
    423
    60
    toronto, canada
    Thanks.
    Just curious why there is the B on the damper if it is not being used?
  7. stream
    2,977
    451
    Long Island, NY
    Probably for a different model.
  8. toyolover
    toyolover Member
    423
    60
    toronto, canada
    Put it back, A to C as instructed.
    Thank you very much.
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    LOL...I did the very same thing the first time I took out my cabin air filter. This forum is a great resource!
    Happy Motoring,
    Tom
    worldaven and toyolover like this.
  10. rebenson
    rebenson Member
    358
    39
    Suburb of Chicago
    Odd, when I replaced filter in my 2010 prius today, it had same issue. After multiple failed attempts I put glove box on without the “damper". When my wife asked, she informed me that this had not worked for years.
    So I guess as long as it closes, no loss.
    padroo likes this.
Loading...
