Need help troubleshooting after market backup camera
Discussion in 'Gen 3 Prius Audio and Electronics' started by SilverSexBullet, Mar 28, 2021.
  1. SilverSexBullet
    SilverSexBullet Junior Member
    Cincinnati
    I did try searching this topic without a ton of success, if there is a similar thread I am sorry for not finding it.
    I have a 2013 prius base model. About 5 years ago I installed a backup camera I bought online that just plugged into the back of the OEM head unit. It worked great no issues for the last 5 years. About a month ago is only works sometimes. Either the screen is all black or it works for a sec and then cuts out.
    I took the whole car interior apart today thinking there was a loose connection somewhere, but found no such issue.
    Anyone else had this issue?
    -Alex
  2. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    the base model oem head unit has a lcd screen?
  3. SilverSexBullet
    Cincinnati
    yeah. I don't believe there is a single Prius without a LCD screen. even my old 05 base had one.
  4. zerotosixtysomeday
    zerotosixtysomeday New Member
    Boston
    my 2011 base has no lcd
  5. Daniel Weiss
    Daniel Weiss Junior Member
    As of 2012 models, there was a "light refresh" that had an enhanced stereo system. This added the LCD Toyota Entune system to the whole lineup.
    2010-2011, the screen was only available on higher trim levels. I just got a Prius II 2010 without LCD/touchscreen.
  6. burrito
    burrito Active Member
    274
    114
    Did you tap into the rear brake lights? Have you checked that that connection is still ok?
