Need help with a part
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ZeroDigit, Jun 7, 2018.
  1. ZeroDigit
    ZeroDigit Junior Member
    23
    Iowa
    I know this may be worrying to much or etc. However I was wondering if anyone knew where I could get this part ? Is it something I can fix or should I just cover it with tape or etc. Any help is greatly appreciated ! 20180606_173534.jpg
  2. ITBland
    ITBland Active Member
    433
    277
    New Orleans, La area, US
    Looks like that should be your rear washer nozzle, I think this is correct: Toyota Part No.: 85391-47010
    Don't try to use the rear washer until you replace it, you will be squirting water inside the hatch!
    Check Amazon/eBay or call the dealer. It should be ~$15-$20
    ZeroDigit likes this.
  3. ZeroDigit
    23
    Iowa
    Thank you so so much ! Sadly I already had some blue fun spray come out, luckily I was able to clean it up easily. I am going to get this replaced asap, until then I will not touch that button !
    51,140
    looks like someone else needed one.:cool:
  5. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    You'll probably have to remove some of the interior panels in order to install the nozzle and hook up the tube.
    ZeroDigit and Mendel Leisk like this.
  6. ZeroDigit
    23
    Iowa
    Luckily I've already done that to the entire interior of the hatch. I've replaced my burned out license plate lights as well too. So replacing the nozzle is gonna be quick and easy !
    bisco and RRxing like this.
  7. ZeroDigit
    23
    Iowa
    Thank you guys so much for helping me with this ! I have fixed the part and it now works perfectly :D No more blue stuff spraying everywhere lol !
    Raytheeagle likes this.
