Need help with bonet OEM stickers
Discussion in 'Prius c Technical Discussion' started by Sonic_TH, Jun 26, 2023.
  1. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    My 2012 Prius C one had the bonet replaced for some reason, it was not in a crash, all the bolts in the front are white, original paint, radiator and condenser do not look new and they have damage from rocks, no bent frame on every angle and a few months back i had to remove the inverter to install a new brake booster and brake pump, there is no front damage. The thing is that the hood was replaced but the replacement did not came with the stickers that have information about the A/C system, the A/C oil, refrigerant type and amount, if some of you guys could share a picture of your bonet, i would like to have that information of the stickers just in case. If i'm correct the stickers are supposed to be in the location where the red rectangles are in the picture below. Thank you.
