Need help with codes on 2002 Prius
Discussion in 'Newbie Forum' started by Izzie, Jul 31, 2012.
  1. Izzie
    Izzie New Member
    2002 Prius
    I
    I have a 2002 Prius with the codes:
    3077
    3000
    3125
    3130
    I was driving along and pressing the gas and nothing happened. I coasted into a parking lot and the big triangle came on. The car was running but when I pressed the gas it did not go anywhere.
    Any suggestions?
  2. BenQ
    BenQ New Member
    Lancaster Pa
    I'm very new to Prius, but I did a quick google on your codes and came up with this.
    Prius Diagnostic Trouble Codes
    p3077 is battery cooling fan malfuction
    p3130 is inverter cooling system malfuction.
    Not sure whwt to do with this info but it's a start for you.
    Good luck
    BenQ
  3. Izzie
    Izzie New Member
    2002 Prius
    I
    Thank you, I will have to take the car to the dealership, because the mechanic that I use does not have the equipment to work a hybrid with these issues. I called the dealer and he said they would have to run the codes again to make sure. Thank you again.
