Need help with EV-Peak CQ3
Discussion in 'Gen 2 Prius Technical Discussion' started by Jbird610, Jul 11, 2022.
  1. Jbird610
    Jbird610 Junior Member
    Arkansas
    I am running into dead ends everywhere I turn. I'm hoping someone on this forum can help me.
    I watched a video by Gregg Festo to help me test the modules of our 04 Prius after receiving the red triangle of death. I purchased the same charger that was in the video, only it's a red model. It says "BGUAD" instead of "EV-PEAK" and the buttons are labeled differently.
    I made sure the settings were exactly what was in the video. I ran my discharge & charge cycle (3x) and when the cycle was completed, I pressed the left button as Gregg did in the video, except I didn't get the same result. When he pressed "Batt. Type" he was able to see the low & high mAh. When I pressed the button located in the same location but labeled "Mode Esc", it took me back to the menu. I ran the scan again thinking I needed to hold it down, but it did the same thing. The other buttons do not take me to the desired menu.
    I also downloaded the software to be able to hook my laptop up, thinking that would be the way I could see the data. The manual says you can use a USB cord to connect them, but I cannot find a USB port on the charger.
    (I love the manual & website tells you all the things you can do with this charger, but doesn't tell you how to do it!)
    Can anyone help me with either issue?
    1. Being able to see the mAh after the discharge/charge cycle.
    2. Connecting a laptop to the charger
  2. Tombukt2
    Tombukt2 Senior Member
    8,964
    1,561
    Durham NC
    Maybe post a link up to the video I don't know the Greg dude I don't know the charger you're talking about are you charging one module at a time I'm guessing so with this hobby charger sounding affair so you've obviously got your battery all apart or you've got the cover off and the battery sitting in the back and you're doing one module at a time or what's happening here guys make this really hard I would think if you had bad modules why wouldn't you just spend the $35 or whatever it is on getting replacement tested whatever modules or even new ones that I don't know what $70 a piece. I paid $1,400 for a whole battery seems to be worth it for 20 years worth of battery.
  3. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    @TMR-JWAP has experience with the CQ3
    Search Priuschat CQ3
    Search Results for Query: CQ3 | PriusChat
    Here is a link to discussion for usb adapter for software. Looks to use temp sensor port to usb
    Does anyone have experience with Ev-Peak CQ3 charger? - Page 4 - RC Groups
    Temp sensor to USB adapter is available at Amainhobbies for $12.99
    Hitec USB Adapter Cable (X4, X4+, X1) [HRC44168] - AMain Hobbies
    #3 alftoy, Jul 11, 2022
    Meg&Bear likes this.
  4. Jbird610
    Arkansas
    alftoy, Thanks for your suggestions. I looked through TMR-JWAP's posts. I had already noticed that he was experienced and knew what he was talking about. I found a post where he shared his settings. I changed my charger to his settings, tried again and it worked! I didn't need to find the adapter to hook up my laptop. I'm running the cycles as we speak.
  5. Ant45114
    Ant45114 New Member
    Charlotte, NC
    I'm having the EXACT same issue you were having with the red BGAUD charger. Can you share the specific setting that needs to be changed to allow me to see the charge/discharge data after a cycle? I changed my settings to match those listed in one of TMR-JWAP's posts but its still taking me back to the menu after a cycle.
  6. Jbird610
    Arkansas
    NiMH settings:
    Charge Man: Current - 3.0 A
    Charge Auto: Cur Limit - 3.0 A
    Discharge: 1.0A, 6.3V
    Cycle: D to C, C+3.0 A D=1.0A, 3 (If it I need to run another charge to double check a number, I change the last number to '1')
    User Settings:
    Precharge time: Off 2min
    Wait time: Chg>Dschrg, 5min
    'Sensitivity: D. Peak Default
    NiCd sensitivity D. Peak deafult
    Temp cut-off: On 80C
    Capactiy cut-off: On, 7500 mAh
    Input power low: Ciut-off 10.0'v
    rest of settings don't matter
  7. Ant45114
    Ant45114 New Member
    Charlotte, NC
    Thanks! Got it working!
  8. leakingimplants
    leakingimplants New Member
    Phoenix
    Hi Jbird610, thanks for sharing, I had the same issue as you previous had with Festo's settings. One question, did you leave Safety timer on and at 720 mins, or did you revert back? I haven't tried a 2nd time yet since i just found this post and made the changes you made.
