need help with key fob (non SKS) programming
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hornbill, May 8, 2022.
  1. hornbill
    hornbill New Member
    UK
    Active
    I am new and this is the first time I am posting here. However, when I have some issue with my car, I always find posts from this forum that are very useful to help me solve my problem. I usually found answers from some posts from this forum without needing to post. We recently got a 2008 Prius, the UK version, which came with only one key (non-SKS, black logo on the back). I wanted to have an extra key just in case so I did a lot of reading on this forum to learn how to do the "chicken dance" to program the key.
    After that, I bought a used fob key (black logo on the back-which the eBay seller said was ready to reprogram, and for some reason, if I wasn't able to, he promised to take the key back). Is was able to program the first part, start the car, on the first try but failed (many times) in the second part, lock/unlock. Then I spent a few more hours reading some posts and found a post, pls see the attached, that helped me to program the new(used) key lock/unlock successfully.
    The only difference in this procedure was pressing the power button 3 times (twice). However, I got into trouble!!
    - As soon as the new (used) key was working both start and lock/unlock
    - the original key stopped working lock/unlock (but still able to start the car)
    I was so freaked out and worried that I would mess up both keys so I didn't try anything yet. I tried to find it to see if some people might have similar problems but I couldn't find it. So I was hoping some of you from this forum might be able to help me!!
    Thank you so much!!
  2. JC91006
    16,774
    8,570
    I think you might have gotten confused on which key is the original one. The used key never got programmed as you mentioned. Using the chicken dance method, it can only program a BRAND NEW key. It cannot be used to program a "used" key you purchased from Ebay. That's why you can't do what you're trying to do.
    The only way to program a used key is to erase the computer of all the keys stored in memory and manually add all the keys (even used ones) back into the computer. This requires special tools and equipment (as well as security clearance). This can not be done using the Chicken Dance
  3. hornbill
    hornbill New Member
    UK
    Active
    Hi JC91006, thank you for the response. I am quite sure which one is the original one as I marked the new one to make sure I won't confuse.
    That is why I got confused when that happened. I didn't see any other member from this forum mention it before.
    I was assuming that the eBay seller has erased or reset the key before selling it. What is more interesting is I was able to open the door that the key comes with the new (used), which is already cut. I can also use the key from my original one to open the door, but just its lock/unlock button is no longer working. Not sure how.
  4. JC91006
    16,774
    8,570
    A used keyfob manual key that you bought off ebay can unlock your door? Now none of this makes any sense.
  5. hornbill
    hornbill New Member
    UK
    Active
    Yes! I know. It didn't make sense to me too.
    I was a bit upset that I got a used keyfob (the seller claimed that it was new), and the manual key was already cut when I received it. I tried to lock/unlock the door with a manual key from both the original one and the one that I bought from eBay and they both worked!
    #5 hornbill, May 8, 2022
  6. JC91006
    16,774
    8,570
    Maybe you should try putting your house key into your Prius and see if that key will open it? Might have a broken cylinder
  7. hornbill
    hornbill New Member
    UK
    Active
    This is not funny! I am not making up the story but just telling the truth about what happened. It is ok if you don't believe it. I myself can't believe what happened either. But please stop mocking. I am not trying to seek any attention by making this up. I am only asking in this forum to see if anyone can help. Thanks!
  8. JC91006
    16,774
    8,570
    Nobody is mocking you, I suggested a house key because the used key from another car should not ever work to unlock your car, unless the lock cylinder is broken
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,051
    1,976
    NJ-USA
    Well, AFAIK, there is no "programming" or "erasing" in the fob itself- on a non-SKS car. The fob has its own unique signal, as well as the RFID chip. These are one direction protocols, from the fob to the car. The procedure you did tells the car, "hey, see this keyless entry remote, and see this RFID? These are good, so let them unlock and start now".
    IDK how the one got erased (I'll assume that the red LED still lights on it and it functions? & that somehow its ID was erased from the car). Up to you if you want to chance repeating the process to (re)add the original fob keyless entry to the car.
    (The SKS fob has the keyless entry part where both the fob and car need to be programmed to each other - " new fob? Meet the car. Car? This is the new fob. You two get to know one another")
  10. hornbill
    hornbill New Member
    UK
    Active
    Sorry! My apologies! I wasn't aware that a house key or any key could manually unlock a car key if the car lock cylinder is broken. I thought you were asking me to do an impossible task :(
    Thank you for the suggestion. I tried with some keys but none of them unlocked the car door. It might be because I was able to insert them only about halfway into the key slot. I will try to see if I can find a key that can insert all the way and let's see what happens.
  11. hornbill
    hornbill New Member
    UK
    Active
    That is what I thought too. I was expecting that the worst scenario would be I couldn't program the new(used) fob. Not the other way around.
    Yes! The red LED is still on it.
    I was thinking about that too to re(add) the original fob but didn't want to take a chance just in case. I don't want to go to a Toyota dealer and spend a fortune :(
    #11 hornbill, May 10, 2022
