Need help with noise 2004 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SirMuffin, May 11, 2016.
  1. SirMuffin
    SirMuffin New Member
    Arlington,tx
    Hello, guys
    My lovely one has problem with this noise and I have no idea how to fix it. it comes from around mid of dashboard through passenger side (not sure). on that day, it just happened when my gf started an engine, and when car moving.
  2. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    The only thing off the top of my head, would be a nut, acorn, etc down in your blower motor housing for the heater. Sometimes it happens when the filter is changed or a critter gets in there and chews it up. When the blower runs, the fins beat the acorn. Does the pitch change with speed changes in the blower? Do I see the clock flashing when it happens? What else happens? Have you changed the cabin air filter recently?
    XT1585 ?
    XT1585 ?
    #2 tony2ltr, May 12, 2016
  3. PA Prius
    PA Prius Active Member
    763
    251
    SE Pennsylvania
    I don' think my '04 has one of these, but it sure sounds like a geiger counter to me.
  4. SirMuffin
    Arlington,tx
    The pitch didn't change when speed changing, but I didnt look at the blower. air filter was replaced 6 months ago. and my car has problem with the dashboard. that doesn't work sometime. I mean it has nothing show up when start a car.
  5. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    The combination meters go bad in these cars, but I think it would be a stretch to blame that right away, although there is a case for it. I'm going to try to open that video of yours on a computer later to see if the noise is any more identifiable
    XT1585 ?
  6. bisco
    51,154
    does she drive okay? maybe the brake accumulator is going out.
  7. SirMuffin
    Arlington,tx
    nothing problem with driving, and the sound comes from behind the display monitor.
  8. bisco
    51,154
    strange that you aren't getting any dash lights. how many miles on her?
    #8 bisco, May 15, 2016
  9. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    That whole deal looks like it is in need of a few good grounds. Does the monitor ever have moving lines on it when the car is running?
    XT1585 ?
  10. Patrick Wong
    18,200
    6,493
    If you are sure the sound is coming from the dashboard, passenger side, then the sound is likely caused by the cabin ventilation fan (try turning off the fan when the sound starts).
  11. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    Ok so. The blower isn't the issue and you have dash lights out? Just illumination, or does your instrument cluster stop working as well? (Speedo, combination meter) how about your MFD/hybrid system monitor? Please list all the symptoms and when they occur.
    XT1585 ?
