Need help with Outlook pretty quick
Discussion in 'Fred's House of Pancakes' started by marjflowers, Nov 29, 2007.
  1. marjflowers
    marjflowers New Member
    219
    Owensboro, KY
    Just on the off-chance someone can help me...
    I was in the middle of composing an e-mail in Outlook, and had to close it out quickly. I thought it was saved, but when I went back, I cannot find it in any of the folders. Is there any way I can get back the message I was working on?
    I haven't had much success searching Help, and I'm grasping at straws!
    Thanks --
    Marjorie.
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I would check in two places: "Drafts" and "Deleted Items". Outlook does periodically save your work as you type, and if you close out of something after saving, it should go into drafts. if you close out without saving, but if outlook had previously autosaved, then it'll go into "deleted items".
    hope this helps :)
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    probably gone. it would be in the drafts folder in outlook unless you specifically save it somewhere else.
  4. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Yeah, sorry. Probably gone.
    For future reference, follow these steps:
    1 - Tools -> Options
    2 - Click the Preference tab
    3 - Click the [Email Options] button
    4 - Check "Automatically save unsent messages
    Even with my setting checked as above, when I attempt to close Outlook it asks if I want to save the unsent message.
  6. marjflowers
    219
    Owensboro, KY
    Thank you everybody so much for your help. Hell of a way to learn a lesson! :(
    Peace --
    Marjorie.
  7. marjflowers
    219
    Owensboro, KY
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Nov 29 2007, 03:09 PM) [snapback]545828[/snapback]</div>
    Okay -- I got as far as Tools, and Options. At that point there wasn't a Preference tab. I looked under every tab and couldn't find anything that resembled "Automatically Save unsent messages." Any suggestions?
    Oh yeah, I have Outlook Express -- would that be the reason i can't change this setting?
    Many, many thanks --
    Marjorie.
  8. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    Just some thoughts, I would create a test email message and do what you did when you lost the draft. It may still be there, especially if Word is its default editor. It may save it as an rtf document and it could be in the temp folders. The test message would allow you to locate it by searching temp folders for something that was created around the time that you closed out Outlook Express. Do you even see the draft folder? If not, it may just not be in your view. Check the view options to see if any folders aren't being displayed yet. Check the sent folder to make sure that it didn't send it. When you closed out Outlook Express, did it show a dialog box asking if you wanted to save it? You can also do an advanced search looking for emails created on the day that you "lost" it.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i do not know...outlook express is good at closing without asking if you want to save...it has none of the standard word processing safe guards built in
