Need help with P0304
Discussion in 'Gen 3 Prius Technical Discussion' started by Haisam, Sep 15, 2024 at 11:50 PM.
  1. Haisam
    Haisam New Member
    Yesterday
    NYC
    I have a 2010 Toyota Prius Gen III. I have read a lot about different opinions and options you guys have provided here and I appreciate it. Here is the pickle. My car is at 297k miles right now. I bought this car at 250k and at that point had head gasket job done on the car. At about 295k I started getting a misfire in Cylinder 4. Did an auto zone provided kit test to see if the color changes and if it is the head gasket. Confirmed that is not the case. Naturally a next thing I did was cleaned the egg cooler, intake manifold, and egg valve. New gaskets and everything. New PCV Valve! Verified that everything is unclogged and good to go. T’s crossed i’s dotted!!! I then proceeded to add an oil catch can. New spark plugs 1 new coil in Cylinder 4 and swapped plug and coil again on number 4. New fuel injectors. The only thing left to do is to swap the injectors or replace number 4 injector too. I feel little hesitations and shake at low speeds and after 150 to 200 miles I get P0304 again. Tried unplugging the EGR to verify if EGR is the issue. Nope! With the EGR unplugged, still have the same symptoms! Visually, the wires and pig tails for the injectors and coils look ok. Haven’t tested them electronically with a tester because don’t know how! If anyone of you have any advice. PLEASE!!!! I am all ears!
  2. Tombukt2
    Tombukt2 Senior Member
    9,873
    1,720
    Durham NC
    I am in the same boat with a 2013 Persona I didn't do a head gasket change I changed the whole motor and was back to the same noise in less than 10,000 mi basically I gave up on the car I have two generation 3s like yours with the same problem and four generation twos with no problems It is obvious to me to drive the generation twos and leave the generation 3s alone I do not want to spend the money to tear apart the engine that's in the generation 3 that was just installed like 12,000 mi ago It is very disheartening but it was expected just to prove a point this was done I am very sorry you are going through this but it seems this is very common in just this engine series apparently we'll see how the two liter AL does but I'm not banking on that being much better I don't really know what to tell you they'll be lots of people coming along to help you spend your money and try to tackle the problem It may not be tackable at this time or you may not want to spend the money The big mistake here was buying the car with 250K on it or whatever you said it was That's a big red flag for this model so it seems at my point in life I'm not interested in running down red flags and problems I've been with Toyota for 47 years so there's always that 2010 and Forwsrd is planned obsolescence and Toyota and a few other manufacturers have implemented this very strategically and very intelligently The people who they are screwing over now are generally people that know no better so it's a win-win.
  3. Mendel Leisk
    38,948
    That kit tests for carbon monoxide in coolant? That is not the usual head gasket failure mode; it’s more typically coolant leaking into cylinders. How’s coolant level in reservoir; monitor it for a while? Also consider boroscope inspect combustion chambers, looking for coolant evidence.
    that sounds like one well used engine btw. How’s oil consumption?
    rjparker likes this.
  4. Haisam
    Haisam New Member
    Yesterday
    NYC
    Thank you for the feedback Timbukt2. I have had many Pri over the years and I inherited the Prius did not buy it. It was a project car. I have Lexus ct200 seats installed and working in it. The car works well just this one issue outstanding.
    Thank you for responding Mendel! So I used the test kit that has blue liquid in it and it did not change color. I have not seen coolant being lost or any oil consumption at all. Have been tracking it for the past few thousand miles. I looked in the cylinder using a camera. But the camera only looks straight down and I did not see anything to suspect a coolant leak, perhaps altering driving another 1k or 2k I will get a camera that can look straight down and to the side to inspect head gasket leaks. Maybe it is so small and slow that it’s not showing in the coolant reservoir tank but is still leaking. I will check and report back. I did see a little bit of oil on the spark plug. Perhaps the O rings around the valve cover are leaking a bit. Could that be a cause ?
    #4 Haisam, Sep 16, 2024 at 11:28 AM
  5. Haisam
    Haisam New Member
    Yesterday
    NYC
    Would really appreciate it @rjparker could chime in. I would really appreciate your advice in this matter.
  6. Tombukt2
    9,873
    1,720
    Durham NC
    At some point you may run into a camera that you can rent or borrow that looks backwards after you stick it in the hole because you want to look up at the gasket mating services of the cylinder head and block assembly yeah I know it's kind of crazy but they make cameras that do that And of course I'm imagining your EGR circuit is all cleaned and up to par.
  7. Mr. F
    Mr. F Active Member
    381
    235
    Washington
    A borescope inspection is the definitive test of early stage head gasket failure since there will not usually be massive coolant loss. This has you pressurizing the coolant tank to about 15 psi and watching for leaks inside the cylinder.
    A rental kit from any auto parts store will let you create pressure, but none of their adapters currently fit the Prius coolant reservoir. An adapter that is known to work is the CTA Tools 7103 which you may need to purchase.
    You'll also want to get a full HD dual lens scope. The side camera will let you perform the critical check for coolant droplets seeping through any gaps between the head gasket and the head/block. These days, a $20 unit can be purchased that employs a user-supplied smartphone as the display.
