Need help with premium stereo and hooking up amp/sub
Discussion in 'Gen 2 Prius Audio and Electronics' started by sneakyboo, Aug 5, 2009.
  1. sneakyboo
    sneakyboo New Member
    Missouri
    Hello-
    Need to know if the JBL factory stereo in 2008 Prius has RCA's to hook up an aftermarket amp. Also, I have the soundsystem with 9 speakers I think and I am wondering if the system already has an amp and if so, where and how do I disconnect it? Thank you!
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Sorry, no!
    That would be the JBL system, The power amp unit is located under the passenger seat.
    Start searching POSTS, not THREADS, for this.
    It has been discussed many times!
    Beware, if you also have the NAV system, the voice goes through the JBL system.
    If you just want to add an aftermarket subwoofer, use one that takes a speaker level input, like a BOSS BASS 600, 800. Your choice! That's an easy hookup. Did it mysef, sounds great.
    Read the folowing thread,
    http://priuschat.com/forums/gen-ii-...boss-bass-600-8-powered-sub-2.html#post918184
  3. HardcoreWR
    HardcoreWR New Member
    The Netherlands
    I just wanted to share my own project with you guys :)
    Bestandsoverzicht van /sub-prius/
    Greets,
    Leon
    The Netherlands
    P.S. You should use the Helix AAC adapter, wonderfull device! I did the same :)
  4. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
  5. kevin434
    kevin434 Junior Member
    baltimore,maryland
    I need help hooking a amplifier up to my 2014 prius hybrid plug in
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    you need to go to the gen3 forum.
