Need help with the key
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aung, Jul 29, 2021.
  1. Aung
    Aung New Member
    Phoenix
    My key suddenly stopped working. I replaced the battery and can see the little red light flashing. I can't unlock or lock the door. Car beep when i turn off the car and open the door. It flashes the lock red symbol. I can turn on and turn off the car. There is no " no key detected warning"
  2. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    Sounds like the key is working just fine except for locking/unlocking the door. Try disconnecting the negative terminal on the 12V battery for a few minutes, reconnect, and try it again.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Buttons may be stuck?
    open back up and put back together
  4. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Chey12v battery
  5. Aung
    Aung New Member
    Phoenix
    How do i go about doing that?
  6. Aung
    Aung New Member
    Phoenix
    I opened it and put it back together. That not it
  7. privilege
    privilege Active Member
    659
    169
    Birmingham
    I'm just commenting so I can find the cause/effect later.
    key fob
  8. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    key fob buttons were worth a try!
    the 12v battery is in the back hatch.
    Open hatch and on the side there is compartment lid to open.
    Use an adjustable wrench to loosen the clamp on the battery,
    put a bag or something around that detached cable so it does not touch/connect back to battery.
    wait 5 mins
    reconnect the cable to the post and tighten.
    Do not let cable touch anything and if you have metal wrench, do not short out by touching both posts.
