need help - recommended tire pressures?
Discussion in 'Gen 3 Prius Fuel Economy' started by harith, Jan 5, 2018.
  1. harith
    harith New Member
    jordan
    Hi everybody my car is 2015 prius persona
    and my question is what's the recommended tiers pressure for best fuel economy ?!
  2. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    Good Morning. A search on Tire Pressure should give you all kinds of information.
    KennyGS likes this.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Owners tend to inflate several psi over the recommended tire pressure on your door sticker.
    harith and scona like this.
    49,455
    welcome!
    42f/40r is common, some run a little lower if the ride is too stiff.
    harith likes this.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I do not inflate to best fuel economy, as that is not safe. i inflate to best handling and longest tread life.
    Depending on the tire itself, that may be 38 to 42 PSI in front, and I follow Toyota's recommendation to have the rears 2 PSI less.
    Danny3xd and harith like this.
  6. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    I run 42/40.
    jack black likes this.
  7. Mendel Leisk
    38,710
    Keep in mind OP has 17" low profile tires.
    Door sticker says 33/32 psi (front/rear). I set our's (215/45R17 Michelin Pilot hx MXM4) at 36 psi, for all four. That pressures seems a reasonable bump, without getting too harsh (it's harsh to begin with) and I find varying front/rear pressures by one pound trivial, and a pain when you're rotating.
  8. Jamieconway
    Jamieconway New Member
    UK
    Passenger-car tires are typically 5 to 15 p.s.i. below the commonly recommended level of 30 to 35 p.s.i. Under-inflated tires add resistance, making your engine work harder to push the car along the road and burning more fuel.
  9. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    In cold non-rainy/snow weather, air up the front tires to the max PSI spec printed on the front tires. Air up the rear tires 2 psi LOWER than the front tires.
