Need Help
Discussion in 'Generation 1 Prius Discussion' started by Sloan24, Dec 5, 2021.
  1. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    So I have a 2003 Pruis that is shutting off while driving, and will shut off if gears are shifted (park to drive or reverse). It will also shut off if revs are not high after about 5 min. We have replaced the 12v battery. We have replaced the fuel pump and filter. I don't really know what to do next.
  2. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    Sloan24 likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    AND.....while it is doing all of that, are there never any trouble codes set ?
    All kinds of warning lights should come on, I would think.
    Sounds to me kind of like your hybrid battery system is failing.
  4. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    I'd kind of like clarification on what it means to say "shutting off." Describe exactly what happens. I'll have to assume that you already know that the gas engine is supposed to "shut off" under all sorts of conditions. But I hate making assumptions... Either way, what you said is too vague to provide a response. And if things are that much of a disaster, as sam spade 2 said you'd have warning / error lights on the dash.
    WHCSC likes this.
  5. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    It completely shuts off, engine is off, not idling. Lights are still on but nothing else. No error codes on code reader. Sometimes there are the check engine light or abs light but not always.
    Thank you for a helpful response. We are going to try that and see if it works.
    #5 Sloan24, Dec 6, 2021
  6. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    If lights are still on, then it's not "completely shut off." Does it say "Ready?" Are you saying is has no power at all and won't go when you get on the accelerator? The engine is supposed to shut off when it's fully warmed up and not actually needed for propulsion.
  7. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    I don't know how else to explain it to you. The engine is off, not idling. I know what idling looks like on the Prius I've owned this car for 7 years. Doesn't respond to gas when I press on the pedal. It's like I turned the car on but not started it even though it is.
  8. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    And I don't know how else to explain it to you. If the dash lights are on and it says "Ready" over the PRNDB display then the car is on an ready to go. This is the case whether the gas engine is idling or not. Get over the whole "engine running" issue. If the car is warmed up and you are sitting idle, then a real problem would be the opposite - that the gas engine KEEPS RUNNING. It's SUPPOSED TO shut off until your foot on the accelerator asks for enough a** to make the car go.
    So if that is the case - you hit the accelerator and the car doesn't go and/or the gas engine doesn't kick in as needed - then the first thing I'd wonder about is the accelerator position sensor. You might be pressing on the throttle but if the sensor attached to the throttle can't "see" that, then ... well, nothing would happen because the ECU doesn't know you're asking for power. So it will remain sitting in Ready mode with the gas engine off and not sending any power to the wheels.
    Do you have any kind of an automotive scanner?
  9. ChapmanF
    15,509
    Any way you could post video?
  10. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    My car has never said ready anywhere on the dash in the seven years I have owned it. I have already stated that we did a code reader and nothing showed up. I know what the car looks and sounds like in idle, it isn't doing that. Like I stated before, it looks and feels like it's in ON position even after starting it and running the revs up.
    It looks like you might be saying there is an issue with the throttle sensor, I will check that as well as the other suggestion from another person.
    #10 Sloan24, Dec 7, 2021
  11. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    I could, however the sound probably won't be great. There is an ABS alarm or something that I haven't been able to figure out.
  12. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    Sigh. Look up top center of the dash where your speedometer is and where the PRNDB (Park/Reverse/Neutral/Drive/engine Braking) indicator is. Everytime you start the car, when it is ready to go, it says "Ready" right above that. It's called "Ready mode" - and it tells Prius (or more generically, hybrid) drivers that the car is on and ready to go even if the gas engine isn't running.
    A code reader is not necessarily a scanner, but many are. if you have a scanner you can look at "live data" - various aspects of what the ECU sees as it is happening. Even if it's just a generic scanner that can't read fancy Toyota stuff, any of them will give you a reading for a "throttle position sensor" (TPS). This isn't exactly the same thing as the accelerator position sensor. But if you could catch it during malfunction and graph the TPS readings it just might tell you a lot.
  13. ChapmanF
    15,509
    Are you postitive this car is actually a Prius? Are you saying you have never seen this indicator on the dash in seven years?
    Can you describe that any further? What leads you to think it might be ABS?
  14. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    Would you quit patronizing me or mansplaining my own car to me? There is NO ready when my car starts EVER. My coder does have live data, there is nothing showing up. Even when I have taken it to a shop. You are now blocked, so rude not helpful.
  15. ChapmanF
    15,509
    I'm not the one asking for help, and for you to usefully get any, by this point you'll probably need to include images or video of the dash in your car, because if it is somehow different from the illustration in #13, there won't be any way for the rest of us, who are familiar with the normal dash indicators, to know that.
  16. Sloan24
    Sloan24 New Member
    CA
    2003 Prius
    i am 100% positive that my car is a Prius. I have never seen that. I was lead to think it's ABS by the fact that the ABS light is on.
  17. ChapmanF
    15,509
    I don't think your earlier posts mentioned that the ABS light is on.
    With that light on, there certainly are trouble codes, at least in the brake ECU, if not in the other ECUs in the car.
    If the scan tool you are using is not showing you any codes, you have an easy option to get the brake system trouble codes without needing any scan tool, using the method where you jumper the Tc and CG terminals and count light blinks, as described further here.
    Not all of the ECUs in the car participate in the code-blinking scheme; there are a couple that can only be read by a scan tool (and only by the few scan tools that work with Gen 1 Prius, at that).
    But several of them do, definitely including the brake ECU, and even just having those codes will be useful progress.
  18. rjparker
    rjparker Tu Humilde Sirviente
    7,921
    4,687
    Texas Hill Country
    Many lower cost code readers and those used at auto parts stores rarely read the specialized codes of a Prius. A first generation Prius looks a lot like a Corolla of the same year. 40575FC3-4DD7-4811-9142-1F699FB8D9FF.jpeg
  19. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    I've owned my '01 since 2003, and didn't recall ever noticing the 'ready' light either. Had to go out and start it just now and sure enough it's right there above the gear shift indicator. It's less obvious with the gen1's, since unlike newer generations, the ICE always starts up like a normal car when you turn the key, so that's how to know it's on.
  20. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    Looks a lot more like the Toyota Echo in its day.
    Raytheeagle likes this.
