Need Ignition coil Gaskets
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rehgarde, Feb 5, 2019.
  1. Rehgarde
    Rehgarde Junior Member
    Fairhaven, MA
    I just had Check Engine Light issues, with 3 cylinders misfiring. I was able to fix that with new plugs.
    My issue, when I removed the ignition coils, I found that 2 of the coils were missing the gaskets, and one had some dirt in the hole, the other had water.
    Where can I get these gaskets? I can't seem to find them online. I have denco coils, and they looked good, the issue is resolved, so I don't want to replace the coils.
    Thanks for any guidance!
    Brandon
    2012 Prius PlugIn
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Water in plug well is caused by the gasket on the edge of the windshield water dam seal has deteriorated or is no longer glued down. There was a TSB for that years ago. If its in good shape just get some weatherstrip glue and glue it back down. if you pull on it you'll see its no longer glued down.
    Also the car has to see torrential rain for the water dam to overflow or its clogged with leaves. Using a control flow garden hose fill up the dam with the hose and you should see good flow out of that dam behind both front wheels. Nice strong stream from behind each front wheel. If not that dam is clogged and water is just pouring over the dam right onto the top of the engine.
    SFO likes this.
  3. audiodave
    audiodave Active Member
    800
    272
    US
    This just a screenshot but it's what I think your looking for. From Ebay. Screenshot_20190206-071441.jpeg
    SFO, JC91006 and Skibob like this.
  4. JC91006
    16,827
    8,600
  5. audiodave
    800
    272
    US
    I know. Was going to buy them for hell of it but after that didn't bother.
  6. Rehgarde
    Fairhaven, MA
    Found a good price + Shipping at RockAuto. Ordered two, installing this week.
  7. audiodave
    800
    272
    US
    I bought 4 from them last week and replaced them. Old rubber was from 2004.
