Need inputs before I buy this used 2011 Prius TWO
Discussion in 'Gen 3 Prius Main Forum' started by ian2002525, Mar 5, 2015.
  1. ian2002525
    ian2002525 Junior Member
    22
    Nashville, TN
    Hi everyone,
    I'm about to pull the trigger to own my first Prius in my life. Before I'm going to pick up this 2011 Prius Two, I need every experts advice for how to inspect and to test drive the car.
    Here is the little info on the car:
    Asking price: $13500. 2011 Prius Two, not II since Roman numerals were used for model year 2010, Clean title, 36k miles, still has warranty thru Carmax till 04/2019 or 100k miles.
    Any common mechanical issues to this year model? How do I inspect the car? How do I check for the condition of the battery? Do I need to replace/maintenance anything right after I purchase the car?
    Thank you so much for anyone's input!! I'm so excited to own a Prius soon!!
    49,842
    no issues, nothing to check really. you could take it to a dealer, but i wouldn't bother. i have heard car fax doesn't get every accident, so that may be something to look for, if you're qualified. if the maintenance is up to date, the only thing you might consider is replacing the tranny fluid if you're going to keep the car long term.
    ian2002525 likes this.
  3. ian2002525
    22
    Nashville, TN
    Thank you so much for the input.
    May I ask where do you recommend to bring the car in for changing the tranny fluid? And how much does it cost?
    thank you once again!
    49,842
    you can take it anywhere. there is a drain plug and a fill plug. after you drain it, you fill it until it's up to the bottom of the fill plug threads. the plugs have crush washers that should also be replaced. a dealer get $100.-$150. if you have a local mechanic, you can pick up the correct fluid and washers from the dealers parts department, for $25. - $30.
    Merkey and ian2002525 like this.
  5. ian2002525
    22
    Nashville, TN
    Anymore suggestions I will be very appreciated.
  6. ETC(SS)
    6,589
    Look to see if all 4 tires are the same, and see if there is a maintenance record for this car.
    Small FWD cars need to have their tires rotated religiously or you'll wind up cupping the rears and get the "whaa-whaa-whaa" thrumming sound. Listen for that when you test drive the car.
    It's not a big deal, as tires are cheap for this car (less than $600) but non-OEM tires at 36,000 miles might indicate abuse/neglect for those first three formative years.
    See if the records indicate that the aux (12v) battery has been replaced.
    If not, then you're due and you may want to start researching a replacement. Optima batteries used to be popular, and they're going to be more expensive because of the battery location.
    Important:
    If this car is being offered through a Toyota dealership, then insist on two key fobs. If it is a Toyota dealership, then how they react to this request will give a good indication of their honesty.
    Good Luck
  7. bisco
    49,842
    one thing i recommend for a quick and dirty check of hybrid operations is to reset trip a or b, and take it for a 20+ mile test driver on back roads to make sure it registers at least 50 mpg average.
  8. KenSoren
    KenSoren Junior Member
    31
    Yucaipa, CA
    This "test" would keep you from buying one in our area. Maybe if you are a driver with experience in how to drive a hybrid, and are on the flat lands with little traffic you can get this but in our hilly community probably won't happen. My wife just drives the car normally and averages around 44 mpg per tank on the trip computer with actual computed mpg of about 41 mpg. Sounds low but mostly in line with Consumer Reports average combined of 44 mpg.
    Otherwise, look for a service record to show that regular oil changes plus other basic services have been done. Since you have such low mileage you should be good to go.
  9. bisco
    49,842
    but combined is highway/city, no?
  10. KenSoren
    31
    Yucaipa, CA
    Yes - combined city highway from CU was 44 mpg but they also had a big span between highway at 55 mpg and city of I think 32.
    The best I ever got in our '15 Prius Three was on a trip to Grand Junction with an calculated overall of 44 mpg. One leg from Cedar City to Yucaipa with 48 mpg for that part of the trip is the best ever for the car, and this is mostly due to lots of stop and go traffic between Las Vegas and Barstow. This is when the Prius really shines!
    Saying you should see over 50 mpg in a 20 mile trip is really optimistic unless like I said you are on really flat land with sparse traffic and know how to nurse the care along.
  11. bisco
    49,842
    i don't disagree completely, and i have no idea of the topography around nashville. but driving 30-40 mph streets around me has always produced 55-65 mpg in decent weather.
  12. Sabby
    Sabby Active Member
    295
    127
    SoCal
    It should have had fresh air filters for the engine and cabin at 30,000 miles. It also should have had a brake inspection/lubrication. If these have not been done have the dealer do it as part of the purchase.
  13. littlehandegan
    littlehandegan Junior Member
    Charleston, SC
    You will be very happy.
    Carmax has a fairly strict routine to sell a car, also the warranty they have is one of the best.
    However, read the fine print to see if hybrid drive/battery is covered.
    Fun read on an editor of jalopnik who buys cars from carmax with warranties : My Air Suspension Failed (Again): Another CarMax Warranty Update
  14. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    That mileage is very low. If you check the maintenance history, then you should be fine. The price sounds good to me.
  15. ian2002525
    22
    Nashville, TN
    Great info, very helpful comments!!
    I will find out the car by tomorrow. :)
  16. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Get two fobs wherever you buy the car. The car was delivered new with two so there's no reason to accept only one because the car is used. The tonneau cover should be present. Mats are an accessory so they may not be included.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    You basically want to inspect it to the standards you would ANY used car. That means inspecting body panels for damage, dings, dents, rust and alignment.
    Tires for wear and condition. And any abnormal looking wear pattern.
    It's true Carfax may not catch every accident...they need to be reported, BUT I'd still want to see one. There's more information than just that on a Carfax report. You can get titling history and things like whether it was privately owned or a fleet vehicle.
    You want to obviously inspect the interior for condition. Lights, signals...check doors and the hatch.
    Make sure the radio is working including speakers.
    I approach any car buying situation, and especially used, with the attitude that I want as much information about the vehicle I'm about to purchase as possible.
    If you're excited and anxious to become an owner, it's easy to get caught in the ether of car buying. So I always keep in mind that the vehicle is "theirs" and their problem until I buy it, and it becomes "my" problem. This attitude motivates me to try to uncover any problem before I sign on the dotted line and while I can still leverage the dealership to do something about any problem I might discover that isn't a deal breaker.
  18. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    That sounds just like our 2011 that we just bought outright after the lease was up...same mileage and price. We just had to replace the tires due to a tiny bit of hydroplaning at 75 AND a nail in the shoulder of one of the tires...replaced with the same brand. We also run 41 psi tire pressure and used the tpms trick so the light does not come on from over inflation. The ONLY thing we needed to do other than that was a set of new batteries for the key fobs. We leased it new back in Jan, 2011 and traded in our 01 Chrysler mini van. Just the mpg difference between the two was enough to actually make the lease payment! Of course, that was when gas was $4 a gallon. but even now she's saving over $100 a month compared to the van.
    Forgot to add...we have the oil changed at Beck Toyota every 5000 miles since I don't like the 10,000 mile interval. They only charge $59.95 for the proper 0-20W full syn change! We also have the tires rotated, but not there...one of my drag racing sponsors does it for free.
    #18 ataylorracing, Mar 8, 2015
  19. ian2002525
    22
    Nashville, TN
    Bought the car today with two key fobs, all the trunk cover, mats are presented. Tires are still factory Bridgestone's with 6/10 life left, factory 12V battery. Done oil change and tires rotation at Firestone 1500 miles ago.
    Drove the car back from NC to Nashville, almost 400 miles trip, with front tire 42psi, rear 40psi results the AVG shows 64MPG, and CONS shows 47.8. I assume the numbers seem fine??
  20. bisco
    49,842
    perfect, congrats!(y)
