Need maintenance light won't go off
Discussion in 'Gen 3 Prius Main Forum' started by Cclax98, Nov 23, 2013.
  1. Cclax98
    Cclax98 Junior Member
    Mississippi
    When I got my tires rotated at the dealership, they could not get the need maintenance light to go off. That happened once before, and it was an easy fix, but the person who fixed it is no longer working there.
    They did all that is required to turn it off, but with no response.
    Has anyone else had this issue?
    Thanks
    49,504
    why not try the instructions in the owners manual, it's pretty simple?
    WE0H likes this.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh boy.
    1. With the car in Ready, Select Trip A on the MFD
    2. Shutdown car.
    3. Press and hold the MPH/KPH button on dash.
    4. Press Start button. Hold button above until the data has been reset (as indicated on the screen).
    Welcome aboard by the way, enjoy the ride!
    WE0H likes this.
  4. Cclax98
    Mississippi
    Following the maintenance manuel did not work. They said the reset them many times daily. But in this case it is not working, this also happened once before.
  5. Cclax98
    Mississippi
  6. El Dobro
    El Dobro A Member
    6,979
    3,214
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If you don't mind losing your fuel economy stats, trip meter readings, I would disconnect your 12v battery for say 3-5 minutes to see if it resets what causing the issue.
  8. Cclax98
    Mississippi
    Thanks Spiderman!!!
    I'll keep this in my owner manual for the next time this happens.
    You're amazing!
    spiderman likes this.
  9. El Dobro
    El Dobro A Member
    6,979
    3,214
    He's not amazing, he's SPIDERMAN!
    WE0H and xliderider like this.
  10. retired4999
    2,652
    625
    Eau Claire, Wi.
    (y) :p
    WE0H likes this.
