Need mod help. Locked out of real account due to 2FA
Discussion in 'PriusChat Website Questions' started by UltraJetRefill2, Jan 5, 2021.
Thread Status:
Not open for further replies.
  1. UltraJetRefill2
    UltraJetRefill2 New Member
    Tucson, AZ
    My regular account is UltraJetRefill. I've tried to contact the mods through the 'contact us' link, and also direct email to Danny. My 2FA app is producing an incorrect number, most likely due to a new phone install. I just need the 2FA turned off so I can log in. Not sure what else to do at this point.
    Thx
  2. PriusCamper
    PriusCamper Senior Member
    12,557
    5,086
    Pacific Northwest, USA
    What does 2FA mean? A 2FA app? What is that? I googled it and I'm guessing you're talking about two-factor authentication? Is this related to Bluetooth or Wifi or some other Near Field Communication (NFC) set up with your Prius? Details are always helpful....
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    What he really is saying is that he got locked out because of bad "bookkeeping" at his end.
    He doesn't remember the second "password" so now is screwed.
    Likely will need to continue with this new "account" and should consider himself lucky that he got that to work.
  4. Mendel Leisk
    41,158
    UltraJetRefill2 likes this.
  5. UltraJetRefill2
    Tucson, AZ
    True. I didn't save the backup code. I've usually had good luck backing up my two factor authentication app, but for some reason it was messed up after installing on a new phone.
  6. UltraJetRefill2
    Tucson, AZ
    Sorry, my description was a little lacking. Yep, two factor authentication. I use Duo Mobile, and the app kept presenting a code that PriusChat rejected. I think it was due to a recent switch to a new phone. As Sam Spade 2 mentioned, I didn't keep my backup code safe.
  7. PriusCamper
    12,557
    5,086
    So you're using the tap-a-talk app? That's always been problematic and the problems with that app doesn't give the webmaster of PriusChat many ways to fix problems. Have you tried using the web browser in your phone instead?
  8. UltraJetRefill2
    Tucson, AZ
    I've been using Firefox to try and log in. I've used the app on Google Play, but no dice there either.
  9. Tideland Prius
    16,534
    Disabled. Sorry for the delay.
    Could you try logging in again?
  10. UltraJetRefill2
    Tucson, AZ
    In the infamous words of hacker movies over the past 20 years, "I'm in!!" :D
    Thanks again to everyone for the help.
    Tideland Prius likes this.
  11. Tideland Prius
    16,534
    Excellent.
    UltraJetRefill likes this.
  12. UltraJetRefill
    156
    93
    Tucson, AZ
    It works on the PriusChat mobile app as well. (y) Thanks again!
Thread Status:
