Need MPG Help
Discussion in 'Gen 2 Prius Fuel Economy' started by ru5real, Jun 13, 2015.
  1. ru5real
    ru5real Junior Member
    42
    A few months ago, I did a lot of maintenance work on my Gen II. Here is what I did.
    Maintenance - What am I missing? | PriusChat
    The MPG went down initially, but by the third tank, I was averaging over 50 mpg. Then I went through a period of very little driving (once a week). Now, I'm driving daily but my fuel efficiency has dropped significantly (~40 mpg) for several tanks. I checked the tire pressure and all fluids. The only thing I can think of that could be causing this is that I'm driving much shorter distances, sometimes even less than a mile (I work from home now).
    Has anyone experienced anything similar? Could my short distance driving (which I know decrease your average, due to fuel being used at each start for warm up) be causing this large of a drop? Any help will be appreciated. Thank you.
  2. JC91006
    16,827
    8,600
    This is pretty much how my mom drives the prius, she gets around 39mpg
    ru5real likes this.
    52,363
    yup, and check your 12 volt battery too.
  4. vskid3
    vskid3 Active Member
    773
    228
    The short trips are almost certainly the cause. I would consider 40mpg to be alright considering the driving conditions.
    ru5real likes this.
  5. bisco
    52,363
    i suppose you could reset the avg mpg and go for a long drive to test it.
    ru5real likes this.
  6. alekska
    alekska Active Member
    435
    138
    Atl
    Air conditioning use combined with short trips really kills the mpg
    Alex
    ru5real likes this.
  7. ru5real
    42
    Thanks everyone. That was my hunch, glad it isn't hybrid battery related. Need to confirm with a long drive, just need a place to go. (y)
