Need New Tires = Please Advise ....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusguy84, Oct 26, 2014.
  1. priusguy84
    priusguy84 Junior Member
    24
    Tampa, Florida
    2006 Prius here.
    Need all new tires.
    Tire Kingdom recommends Michelin Premier A/S ( 205 / 60R15 = little wider than stock )
    My previous tires: Michelin Pilots 205 / 60R15 ).
    I like my tires wider than stock because I drive on freeways and feel safer with a wider tire.
    I understand wider tires affect MPG negatively.
    Will buy tomorrow at Tire Kingdom.
    Please Advise.
    Thank you all so very much!
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    My 2 cents.
    Buy the Michelin Defender instead. Better tire wear rating (820 vs 640 for the Premier A/S) and $25 cheaper per tire.
    If Tire Kingdom doesn't sell the Defender, shop somewhere else.
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    My opinion is the same as your's. Michelin Defenders.
  4. Mendel Leisk
    42,330
    Well I'm a premier fan right now. They've got tread that supposedly gets better as it wears, very good traction/breaking, and rolling resistance should be lower than the Defender.
    We've got pilots right now, thinking the next tire'll be Premier, so have a selfish interest: if you go with Premier would like to hear how it works out.
  5. bisco
    52,828
    if you like the premier, get the premier.
  6. jadziasman
    1,355
    488
    District 6
    The OP stated that the tire store recommends the Premiers. Cha-Ching!
  7. priusguy84
    24
    Tampa, Florida
    Premier A/S vs Defender .... Which handles better?
