Need opinion , is it 12v battery or inverter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PeaceWithGod.tv, May 14, 2021.
  1. PeaceWithGod.tv
    PeaceWithGod.tv New Member
    Usa
    Hello, my wife was driving our 04 Prius when she pulled out from a stop sign into a turn lane when the car stopped. She could only put it in neutral and she said all the warning lights came on. Someone helped push her out of the road into a parking lot. She thinks the ready light was off. She could not turn the car off for several minutes and then she was able to shut it off. When she tried to turn it back on all the warning lights came on and it would not shift into any gear. I showed up a bit later and checked for codes and found none. The warning lights went away. This was I believe the 3rd inverter pump I have installed in around a year. I thought another bad pump so when I got home I checked it but it was running. My daughter had limped the car home several miles once when the last pump went out so my question is could the inverter been damaged during all of these pump failures I have experienced and the inverter is staring to fail because of the overheating?
    So I was ready to go get a salvage pump and I thought I would check the 12 volt battery. It settled at 11.3 with lights on. When the pump kicked on 10.8. After setting for a bit and putting it under any stress it would drop below 10 and the red triangle would come on. So now I'm thinking bad 12 volt battery but when the car is running it is normally in the 14 volt range isn't it? Could it still cause a problem when the car is running like my wife experienced?
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    234
    California and Hawaii
    Having a known good 12v bat is the first cheapest thing to establish
    Just my humble opinion
    however if your wife was actually driving when the issue occurred then the 12v bat had already done it’s job - starting the car/booting it up
    I have similar problems with my Gen 2 and 3 Priusses
    the quick dirty fix I use is to disconnect the 12v bat either by unbolting the negative wire or pulling out the big white plug at the positive terminal and waiting 6 minutes or so before RE-attaching
    it then takes one push of the power button, a pause for 15 secs or so, and a second push of the power button to get the ready light and/or the ICE started
    of course this hasn’t fixed anything
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Welcome to PriusChat!!
    Generally speaking, if there are warning lights displayed on the dash there will be OBD2 codes (DTCs) stored in the ECUs.
    Which OBD2 scanning device or App are you using to retrieve the OBD2 codes?
    When the vehicle is in 'ready' it should be charging at around 14 volts. Your 12v does sound suspect, when was it last replaced?
    Many aftermarket electric pumps/valves have been known to prematurely/intermittently fail, did you replace it with an OEM from the dealer?
    Raytheeagle likes this.
  4. PeaceWithGod.tv
    Usa
    My obd2 reader is a cheap amazon or eBay. Same with my pumps. I now believe if this one fails I should get a genuine Toyota . The battery is in the 4 year range at least. Any recommendations on battery brand?
    Now that I think back during the breakdown I had checked the 12v battery with my meter in the back and as mentioned above by JohnPrius3005 I unplugged the larger white cable while I was back there. At the time I had a 12v reading under no load. Now was this before or after I did the code check I don't remember.
    I have 256,000+ miles on this 04 model. I also have a 05 with over 271,000 miles. I have reconditioned both traction batteries and been fortunate to get several miles (years) on both. I bought a 3rd used traction battery I keep in the basement as a quick swap out when one of the larger batteries starts to give trouble.
    One more thing I just thought of. I had a mouse in the car. I trapped him and he is now gone. Has anyone else had problems with mice getting in the car?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    One thing I have learned. Always fix the obvious first. It prevents a lot of tail chasing. The 12v battery needs to be tested and replaced if needed.
    Samuel Williams Jr likes this.
  6. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Start by trickle charging or smart charging the 12v at 4A or less.
    Not all OBD2 scanners are toyota hybrid compatible, you may have to upgrade to something here or buy a 'mini-vci' cable with techstream (same software the dealer technicians use). Know that disconnecting the 12v source will erase any stored obd2 codes (DTCs) in the ECUs.
    It is very likely that the cheap inverter coolant pump has failed, which cause the inverter to shut down, and then depleted the 12v. Once charged/charging, your 12v may be usable for awhile longer. Always buy a 12v with the longest "full replacement warranty" for the least cost.
    Does the vehicle currently go into 'ready' mode?
    If not, have you checked the AM2 fuse?
    After attempting to restart or 'ready' the vehicle, did you scan for obd2 codes again? Please post the codes here for further guidance.
    More than one person has had mice issues, try using the 'advanced search' feature to find the relevant threads and solutions.
  7. PeaceWithGod.tv
    Usa
    The car is running fine now with no codes and goes easily in ready mode like nothing is wrong. I'm going to just go ahead and buy a 12v battery because it didn't take much to start dragging it down. I compared the battery of my 04 Prius to my 05 Prius using the cars battery diagnostic screen and got quiet a difference when putting them under a load. I plan on driving the 04 so I can keep an eye on it and let my wife drive the 05. I appreciate all the help and hopefully I won't be back with this problem. Have a nice day.
