Need overhead hatchback protection
Discussion in 'Gen 2 Prius Main Forum' started by jaw444, Jan 22, 2009.
  1. jaw444
    jaw444 Member
    281
    27
    San Fernando Valley CA Sherman Oaks area
    At first i didn't notice it. When i raise my hatchback with the garage door open, the hatchback comes in contact with the metal braces on the garage door. The hatchback goes up quite high, a lot higher than i need. If the garage door is closed, then there's no problem, but lots of times i want to let the light in from outside and i want to open the hatchback with the door open, which means that the door is positioned low enough to come into contact with the hatchback.
    I would like to put some kind of soft protective surface on the metal braces on the garage door so that when the hatchback comes in contact, it won't get scratched. I have gotten some tiny scratches from doing this without realizing it.
    i can't think of what to use. I'm thinking there is probably a product to use for this, like a kind of tape that has a soft thick surface on the outside, but i don't know what it would be called and as you can see, i have trouble describing it, like if i went to OSH and tried to say what i wanted, i would have trouble getting the idea across. Has anyone had this problem? Or does anyone know of a product that could be used to cover the metal braces on the garage door above where the hatchback is?
  2. essaunders
    essaunders Member
    195
    NH
    I back into the garage for this very reason. I have thought about putting some padding on the metal bits, but haven't gotten to it yet. Perhaps some pipe insulation left over from a grill blocking could be taped up?
    sorry, i see you are in LA. you probably won't be doing grill blocking. : )
  3. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Instead, prevent the hatch from opening that much.
    There's a photo and description how in the User-Guide
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    My parents had this problem when they got their Ford Focus hatchback in 2001. They used pipe insulation to cover the metal braces.
  5. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    We used leftover batting (has shiny on one side) from the blanket around the hot water heater and stapled it to our wooden door. You can get pieces of foam with sticky backing at any hardware store- used for blocking window /door air leaks. You will need a wide one.
  6. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Find the ethafoam pipe insulation. Glue it on with contact cement. Use either 1/2" or 3/4" pipe insulation. It's soft enough yet rugged enough to withstand whatever you do to it.
    You can still scuff the paint if it's dirty or if the ethafoam is dirty.
    Ethafoam is the stuff used for packing of largish objects in boxes. It's usually white or pink in this use and glued to the cardboard. The stuff used for pipe insulation is usually black or gray.
    The other pipe insulation used is a rubbery foam, usually used for air conditioning pipes because it's softer and easier to bend around the sharp corners air conditioning pipes often have. It's usually black. It would work as well. Again, contact cement works well to glue it. You can now get water based contact cement, if you're worried about the aggressive solvents in the "standard" old style contact cement.
    I use ethafoam stapled to the walls to protect the doors when thrown open as my garage is rather narrow. It's available in 1/4" and 1/2" sheet. For this use you can usually recycle packing material as the amount needed is small (provided you can ensure the parking position is tightly controlled). ;)
  7. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Adhesive backed rubber foam, used for insulating referigerator doors, etc. You can get 1" wjde and stick it on the braces. Or, back in, like I did before we got our roll-up door, now, no problem anymore.
  8. jaw444
    jaw444 Member
    281
    27
    Thank you--i like that solution. Would i be able to get hooks like that at OSH? or else where? That user guide is a great resource.
  9. jaw444
    jaw444 Member
    281
    27
    Thanks for the suggestions, that was what i was needing. That insulation stuff was what i was trying to think of, with the adhesive on it.
    I thought of backing into the garage but there's a few reason why i don't want to. The garage opens onto an alley which has a fair amount of traffic and is a social gathering place, and when i get home from work, especially, i don't want to go through a big production. I just want to slip into my garage in one swift move, effortless and easy. Also, sometimes l like to let the light from the outside help me see into the back when i'm taking stuff out or arranging things.
