Need power source for new wifi rear camera.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Solman636, Jul 21, 2023.
  1. Solman636
    Solman636 Member
    99
    37
    Florida Panhandle
    Is there a 12VDC wire in the liftgate that will supply power for the rear camera when the car is turned on even without the lights on ? Or will I have to resort to lights on always to use the camera? Also is there a wire to tap up front for camera display on left side of dash. Maybe in steering column or near fuse box? My multifunction display inadequate quality now for reverse driving, but I also want the camera to get better view of blind spot while driving.
  2. pasadena_commut
    pasadena_commut Senior Member
    1,493
    447
    Southern California
    Not sure which wire you would want, but there are a lot of them which are easily accessible near the fuse box which is near the driver's left knee.
    I think I found your answer here:
    rear view camera using wireless install. | PriusChat
    tap it off one side of the rear wiper motor. I guess that motor is controlled by pulling one side to ground, so the +12V side is available whenever the car is on.
    (Note, in searching for this I ran across a few people who had tried wifi rear cameras on different vehicles and found them to be a little laggy, eventually going with wired cameras.)
    PriusCamper likes this.
