Need recommendation for aftermarket speakers
Discussion in 'Gen 3 Prius Audio and Electronics' started by yam, Sep 22, 2010.
  1. yam
    yam Junior Member
    64
    Austin TX
    Several months ago, I upgraded my 2010 Prius 2 speakers to Alpine SPS-600C components in front and Alpine SPS-600 full range in the rear. They were uncomfortably harsh when running with the factory head unit. I waited in hope that it would improve when I replaced the head unit later.
    I recently updated the head unit to a Kenwood Excelon KDC-X994. The speakers sound better but still harsh, especially at mid to high volume. Even after aggressive use of the EQ and DSP features, I find that they always sound either harsh or muffled. I just can't get the nice clean warm sound I want.
    So I'm beginning to think the Alpine SPS-600C is a poor choice for this vehicle. Does anyone else have experience with this combination, or advice for making them sound warmer and less harsh? Perhaps a recommendation for another speaker that I might like better? I'm considering swapping them out for Polk MM6501.
  2. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I've run both Infinity Ref, and MB Q - The MB is (IMHO) decidedly better than the IR. I'm running them mounted at the A pillar - so they are very direct - but do a great job imaging sources. The IR was good - and maybe a bit more subdued - less dynamic.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I think you need a sub to compliment it.
  4. yam
    yam Junior Member
    64
    Austin TX
    Thanks guys. Keep it coming!
    For what it's worth, I'm running a Kenwood KSC-SW10 powered sub under the seat. It ain't great but it's a lot better than not having a sub.
  5. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Oh so you already have a sub. Is it possible to filter out some highs with the xover that came with SPS-600C?
  6. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    You might also try playing around with the placement & mounting angle of your tweeter...off-axis vs. on-axis response can be notably different. I'd also suggest putting some sound deadening in your doors if you haven't already done that.
    If all else fails, try going to a shop that has your Alpine drivers mounted side-by-side with some others...do some comparison listening to the same music passages and see what sounds better to you. It will, of course, sound different in the car, but that will at least give you and idea about the tonal differences from one brand to another. If you get a chance, have a listen to Focal, Diamond Audio, Image Dynamics, Hertz, Morel, DynAudio, and others that may not be featured at the big box stores.
  7. Thai
    Thai Prius Neophyte
    1,197
    89
    You need to move your tweeters to a more conventional place...maybe the upper part of your front doors with 30 degree axis toward the opposite front seat. This may be the cheapest solution to your problem. I would NOT be so fast to buy another set of speakers. If you buy a new set of speakers and mount in the same spots, then i fear that you will still be disappointed.
  8. ajc
    ajc Member
    340
    38
    pa
    I did a complete aftermarket upgrade - Eclipse CD5030 HU, Alpine PDX-4.100 Amp, Polk MM6501 Component Speakers front & rear, Infinity BassLink Sub. The Polk MM6501 sounds amazing, but I would recommend a good 4 channel AMP (I have the Alpine PDX-4.100) 100 watts per channel.
    Check out my complete aftermarket upgrade -> http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/75574-complete-audio-upgrade.html
    Any questions let me know.
  9. partsmore
    partsmore Junior Member
    85
    NE
    I installed premium speakers from Hybrid Audio - www.batteriesareus.com
    WOW - what an improvement!
    i will be adding an 1000w amp and no subs...
  10. ajc
    ajc Member
    340
    38
    pa
    You will see a major improvement if a sub is added. :rockon:
  11. yam
    yam Junior Member
    64
    Austin TX
    Well I figured out why my speakers sounded so bright. It turns out that my Ipod was set to "spoken word" EQ. Duh! After changing it to "flat" EQ, everything is sounding much better.
  12. Thai
    Thai Prius Neophyte
    1,197
    89
    Haha, sometimes the best solution is right under our nose!
