Need some advice on my tire
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dennis Lai, Jul 29, 2020.
  1. Dennis Lai
    Dennis Lai Junior Member
    California, US
    Hi Guys, I would like some advices for my tire. Please see the picture below.
    I am not sure would this be dangerous for me to drive around? Will I get a broken tire in the middle of my way?
  2. Dennis Lai
    California, US
  3. ydpplqbd
    ydpplqbd Active Member
    551
    253
    bisco and Raytheeagle like this.
  4. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    You need a new tire immediately. I'd drive it to the tire store if I didn't have to go more than a few miles on local roads at low speed, but no further. Did you hit something (curb, pothole,etc.) or did it just pop up? It could be a manufacturing defect and if so would probably be covered to some extent by a tire warranty. If you have a road hazard warranty for your tires now is the time to use it.
    bisco, Raytheeagle and ydpplqbd like this.
  5. bisco
    51,141
    ditto
    how many miles on it?
  6. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    This is what happens when you over inflate the tires and the roads are no good. Get a new tire.
  7. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    That's a blowout waiting to happen. Change it out and drive it to the tire shop for a replacement tire on your spare tire.
    This is what a tire bulge looks like on the tread area, yours is on the sidewall. The bulged area wore down to the steel belts and the tire carcass was starting to separate. Again, a blowout was imminent.
