1. Ozark_Mtn Prius
    Ozark_Mtn Prius New Member
    Branson, Mo
    2007 Prius started losing power got engine codes for bank 1 lean and throttle body intermittent high voltage. Replace throttle body, cleaned MAF sensor, replaced PCV valve, replaced spark plugs. Car seemed to be running fine. Drove it for 2 days and it started bucking and I got misfire on cylinder 4 code. Does this sound like coil, fuel injector? Car has around 240,000 miles. It is daily driver, just to keep miles off my truck and cheaper. Just don’t want to sink a bunch of money into it, but willing to sink a little. Any advise would be appreciated.
  2. Ozark_Mtn Prius
    Branson, Mo
    I have a 2007 base model that started acting goofy. Going I to limp mode, not accelerating, etc. ran a code scan it gave me codes for bank 1 lean and throttle body sensor intermittent high voltage.
    I replaced the throttle body, new PCV valve, new plugs, cleaned MAF sensor and replaced both O2 sensors. Car drove great for 2 days. While driving it started running rough and sputtering. Code reader showed P0304, which is miss fire code, what are the chances it is the coil and could this have been caused by the changing of the previous parts I mentioned? I don’t want to sink a bunch of money into it as it is my third vehicle, but want to continue to drive it. Any help will be appreciated.
  3. JC91006
    16,651
    8,501
    easiest way is to swap the coil to another cylinder. If the code reader has the misfire going to the new cylinder, then it's most likely the coil.
    Danno5060 likes this.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    P0304 is a misfire specifically on cylinder 4. The most likely problems are a bad plug (already replaced), bad coil, bad fuel injector. Less likely problems are a leaking had gasket (check the ICE coolant level in the radiator and in the overflow tank) or a bad wire or connector going to that coil. If none of those are the problem check compression.
    Be aware that Amazon and Ebay are awash in counterfeit Toyota parts. Much grief can be avoided by either buying from a Toyota dealer (often less expensive if ordered online) or from RockAuto (if going with an aftermarket part).
  5. PriusCamper
    PriusCamper Senior Member
    11,977
    4,869
    Pacific Northwest, USA
    Aftermarket coils are cheap and work great because they are standard across many different Toyota models... As for counterfeit products, that's primarily an issue with spark plugs and not much else. But every aftermarket part is different and needs to be examined.
  6. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    Counterfeits in fake Toyota packaging include air filters, cabin filters, water pumps and spark plugs.
    Usually the fake packaging is not crisply printed and will typically say made in Japan when real parts are usually made elsewhere.
    If you are paying 1/4 to 1/2 dealer from anyone but a dealer it is counterfeit.
    #6 rjparker, Jan 29, 2025
  7. ChapmanF
    17,179
    I probably could be talked into taking the risk of a counterfeit cabin filter. Not much to worry about even if it sucks.
    Let's not forget grass-clipping brake pads.
    PriusCamper likes this.
  8. pasadena_commut
    2,215
    661
    Southern California
    Well, normally anyway - worst case you are just breathing unfiltered air. However, the recent Eaton fire was not too far from us and there was a lot of crud in the air. The cars were running "recirculate" whenever we went out so that we didn't have to use N95's while driving. My son's CPAP machine has a filter, and even though it was inside 100% of the time with the windows closed, and the house was never directly in the smoke plume, it jammed up really quickly after the fire. When he pulled it out it was black. First time that ever happened.
    OMG. First the car won't stop and then all the brakes go up in flames.
  9. PriusCamper
    11,977
    4,869
  10. rjparker
    9,485
    5,808
    Texas Hill Country
  11. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    I would think now that coil over the plugs should be a no-brainer in any idiot should be able to manufacture You can make up your own at the house practically I won't be as durable and what have you in packaged like the one specifically for your engine but still these things made by TRQ and all the other no name brand manufacturers these things aren't rocket science I mean if it's just a matter of picking crappy resistors and circuits just because you can well there you go maybe a manufacturer should stick to what they should that sort of thing I think that's what's kind of gone missing here everybody just plops out a bunch of garbage in hopes to sell a few pieces or something It's just almost nonsensical but it's where we're at.
  12. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Misfire can be caused by a number of reasons. Follow the instructions and you will win.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/2054m/cip0300.pdf
    Prodigyplace likes this.
  13. ChapmanF
    17,179
    My transistor fab is down for weeks any time somebody walks in with their shoes on.
    Tombukt2 likes this.
  14. pasadena_commut
    2,215
    661
    Southern California
    Semiconductors are sensitive to insanely small levels of contamination. Thumb print on the wafer? Too much sodium, into the trash.
    Coil packs are not that touchy. They are just two concentric coils of wire wound around an iron core, a spring, a bit of wire, an electrical connector, and some plastic to pack it in. Not very sensitive to contamination. Usually only one diode present. A crappy one will fail early because the manufacturer cut corners too aggressively on wire diameter, wire coating, or some other quality measure and it burns out, shorts out, breaks a wire (blocking a current path), or the connector parts corrode.
  15. bisco
    51,010
    Did you replace the plugs with genuine oem from a dealer?
  16. ChapmanF
    17,179
    Say what? These are not just "coil packs" on our Prii; they are igniters, and include the circuit to power the coil primary from the battery and then interrupt it on signal from the ECM, and send the IGF confirmation signal back. Toyota's diagram leaves the rest of the driver/IGF circuit to the imagination, but definitely shows the important power transistor in there.
  17. rjparker
    9,485
    5,808
    Texas Hill Country
    Simplified Coil Circuit
    Waveform
  18. pasadena_commut
    2,215
    661
    Southern California
    Guess I got that one wrong. More electronic parts than a simple coil pack.
    I don't understand that oscilloscope image.
    IGF fires several times without corresponding IGT. Are all the IGF lines coming from the cylinders tied together into one input at the ECM?
    Also the spark plug current spikes before the trailing edge of IGT and ends its spike right at that edge. Shouldn't it spike starting when the transistor between the coil and ground's control input goes from high to low? I can't read the numbers on the X axis. Is increasing time in that plot left to right or right to left? Where is +12V in the simplified diagram and does "ignition control circuit" invert the IGT voltage shown in the trace?
  19. rjparker
    9,485
    5,808
    Texas Hill Country
    Yes you can see that in the Prius wiring diagrams.
    The battery symbol is on the left.
    Toyota Ignition Diagnostic article
    Dotting the IGFs and Crossing the IGTs
    #19 rjparker, Jan 30, 2025
  20. PriusCamper
    11,977
    4,869
    My theory is that evaluating these aftermarket ignition coils is best done by weight. Because the more copper the coil has the better it will perform. What do you think?
