Need some explanation for these 2 sounds
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Eric Vasaio, Jul 17, 2019.
  1. Eric Vasaio
    Eric Vasaio New Member
    BC, Canada
    2013 Prius Plug-in
    So I've got this 2013 PiP 2 month ago. I always hear these 2 sounds from this suppose to be very quiet car. I tends to think they're just normal sounds but...
    First, humming electric motor sound. Especially under low speed and gentle brakes, I can hear this bee humming sound relatively loud. If you have an old style not well lubricated electric fan in summer time, that's the sound.
    And then, every time, about 1 minute after I shut the car off, there's always a clunk sound from front of the car, maybe from under hood, or maybe from brakes which is really hard to tell. As if two metal pieces get engaged or disengaged.
    Are they normal Prius sounds? thanks for any input.
  2. Tideland Prius
    16,611
    The first is probably the Vehicle Pedestrian Notification System. It cuts out over 10mph or so.
    Not sure about the second.
    Eric Vasaio and Mendel Leisk like this.
  3. ChapmanF
    18,513
    Self-test of brake system, couple minutes after power off, every time. If you listen carefully, it's more than just "clunk", but more like "clunk ... clickity squish ... squish clunk".
    Utterly normal.
    Sometimes, it will need to repressurize during the test, so you'll hear the brake pump too ("whirrrrRRPclunk"). Not every time. Depends on what the accumulator pressure happens to be when the test starts. Don't be concerned because you do or don't hear it every time.
    If the car detects any problem, it'll tell you. That's why it self-tests. No news is good news. :)
    #3 ChapmanF, Jul 17, 2019
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I’ve had my Prius 18 months now. I’ve heard just about every noise the car can make. However, some of my family members are still surprised when it starts itself or pressurizes the brakes jaut sitting in the driveway. They think it’s haunted. I tell them the car is just smarter then all of us and is getting ready to leave.
  5. bisco
    52,362
    you're car starts itself?:eek:
  6. ChapmanF
    18,513
    I am Car Starts Itself. There's not room for two of us.
    Eric Vasaio and bisco like this.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    When parked in “Ready” mode and the ICE restarts. LoL.
  8. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    The first noise is the braking system building vacuum once in a while
  9. ChapmanF
    18,513
    ... except that there is no use of vacuum anywhere in the braking system. There is a pump that puts brake fluid into a high-pressure accumulator though.
  10. Eric Vasaio
    BC, Canada
    2013 Prius Plug-in
    Thanks, I found a video on YouTube, exactly this sound. Link of the video:
    What a relief. Thanks again.
  11. Tideland Prius
    16,611
    From our very own PC member @F8L
  12. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    In general: The Prius makes weird noises. You'll get used to it :)
