Need someone to program new smart key for my prius
Discussion in 'Gen 2 Prius Technical Discussion' started by Priusowns, Nov 21, 2008.
  1. Priusowns
    Priusowns New Member
    Hayward California
    Okay i need to find a technician that can program the key for my car. Dealer i called is talking about reseting ecm etc and 4 hours labor.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The fob is not programmed, the car is programmed to accept the fob. The dealer is your only option I believe.
  3. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    It sounds like you have lost both smart keys, correct?
    If so, yes, it is expensive. ($500 minimum)
    If you still have one of the two (that came with the Prius), then, it should costs much less.
    (i.e. smart key + 1 hour labor -> $200-300?)
    Cost I mentioned is for 1 smart key only. The reason is that the procedure is much simpler with a reference key. It seem like the reference key can provide much information to make programming the second key faster and easier.
