Need someone to talk me into or out of a Prime
Discussion in 'Prime Main Forum (2017-2022)' started by ssdesigner, May 16, 2018.
  1. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    So I live in MN where it's cold 4-5 months out of the year. I have a 2016 Prius 2 with 9000 miles on it. I've done a number of small updates to it (window tint, door ding detail strips on both sides, weather-tech mats etc) and I've got $1K into the sound system.
    My work commute is 3.5 miles each way. Top speed each way is 35 MPH. That's 90% of my driving. I know that the Prime will kick in the ICE below a certain temp outside (20 degrees?) and that it will not let me sit with old gas in the tank for years....so the ICE will be running a fair amount.
    Am I crazy to want to trade up for a PiP?
    I am looking at a $30K Prime Advanced at a dealer, and my KBB for dealer trade-in is $18K. :/
    #1 ssdesigner, May 16, 2018
  2. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    What is the other 10%?
    Raytheeagle likes this.
  3. ssdesigner
    304
    241
    california
    2013 Aqua
    Random freeway driving. Smaller 10-15 mile trips at 60-65 MPH.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    I have a similar debate to your question in my head, but I fall back to we have a 2010 that is paid off:).
    Is your 2016 paid off? Are you ok with taking a depreciation hit when you sell or trade your 2016 in? Is the only reason for saving on gas?
    For now, I’ll keep running our Gen3 until a maintenance expense exceeds what the value of the car is, which at 179 k miles currently and growing at a rate of 80 miles a day, is getting less and less:(.
    But each day one step closer to a Prime (y).
  5. ssdesigner
    304
    241
    california
    2013 Aqua
    Not paid off, I still owe $14K on it and the KBB is $18K via dealer trade-in.
    I'm ok with taking a bit of a hit if I can drive with less gas, but the more I read I'm not sure how I feel about the ICE on the Prime kicking in despite it being set to electric only.
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    If just a gas use decision and nothing else, at 9 k miles a year, you have a lot of driving to do to make up the difference between a gen4 and the Prime;).
    Some folks like the newest version out, so if that isn’t a driver to switch, I’d stick with what you got:).
    Just my opinion, but one from a guy who has considered a Prime for over a year(y).
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    IF.....you have the cash to pay the difference, then go for it.
    If not, then the answer to the above questiion is: YES, absolutely.
    Given the circumstances, this is a BAD deal, financially.
    If you add in financing costs it gets even worse.
    Dudley1030 likes this.
  8. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I don't see any practical or financial sense in doing such a trade.
    But it's okay to do it just because you want it. Just make sure that you want it bad enough since it sounds like it may interfere with getting other things you want.
    If you want to save money and gas, keep the car you have and add a block heater on a timer. If the ICE starts each day already warmed up from cheap grid power, the car is smart enough to run it much less for warm-up.
    toyopri808 and Mendel Leisk like this.
  9. MNdriver
    MNdriver Senior Member
    549
    577
    I'm also in Minnesota and sold my Gen 2 Prius for a Prime. I have a similar short and EV friendly commute. I don't regret the move up (and it definitely is a move up) one bit! I drive almost exclusively on electric. However, as you know, we had a pretty brutal winter, so many days in December, January and February, when the temp was below 14 and I turned on defroster, the ICE kicked in. The result is that I used 1/2 tank of gas between December, when I filled up, and now. Love my car!
    HPrimeAdvanced likes this.
  10. Mendel Leisk
    40,586
    Yeah way to soon to be trading in. Resist the urge; it'll pass.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Wait a bit longer for a 2019 or 2020 model.....
    Rob43
  12. bisco
    51,155
    @john1701a is your go to in mn.
    Come east and save an extra 4K.
  13. ssdesigner
    304
    241
    california
    2013 Aqua
    If I wait until 2020 I'm hoping that my purchase will be an all-electric solid state battery Prius. :)
    HPrimeAdvanced and EazyPeazy like this.
  14. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    ICE will not kick in until you reach 14 F if the following criteria are met refrain from using cruise control below 50 F, refrain from using front defrost, the car has a heat pump that will defrost your front windshield when you set climate to auto and 65 F (this will not cause ICE to kick in but will take a couple miles off your EV range estimates)
    HPrimeAdvanced and bwilson4web like this.
  15. bisco
    51,155
    don't go down a large hill with a full charge.
  16. bwilson4web
    16,012
    In May 2016 I was offered a Prius 3, new, for $28k. It had TSS-P but sad to say, a useless 'moonroof'. So I bought a used, end-of-lease, 2014 BMW i3-REx and never looked back.
    You have a fine Prius and my recommendation is to wait 5-6 years and enjoy the ride. THEN look at the market and choose a replacement based upon the technology of 2012-2013.
    HPrimeAdvanced and Raytheeagle like this.
  17. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Yep. With how smooth and quiet all electric driving has been, I get a bit annoyed when the ice turns on. But love the range between fill-ups. By the time my 2017 Advanced is paid off, an all electric version will be available. Lol
  18. Tideland Prius
    16,445
    Instead of focusing on the negative, (i.e. the engine running in the winter), focus on the positive (engine not running in the summer) :)
    Honestly, I would wait - see what the midlife update brings. Or wait for the next gen Prime or see what Toyota does with the next gen Prius (maybe it will be an EV).
    Solid state is still a few years away so if you're ok with waiting (and it seems like it), we'll see if Toyota will jump on it immediately or wait a few more years and let others take the initial hit on the investment first.
  19. sam spade 2
    7,035
    2,799
    2017 Prius c
    Back to the future ??
    Maybe they will have a working flux capacitor by then. :ROFLMAO:
  20. bwilson4web
    16,012
    Was thinking 2022-2024 typed it wrong. In 4-6 years, we're going to see much better technology at affordable prices.
