Need someone with electrical knowledge to confirm this....
Discussion in 'Gen 2 Prius Audio and Electronics' started by bobc, Mar 3, 2005.
  1. bobc
    bobc New Member
    361
    Durham, NH
    I rarely ever switch from fresh air to recirculated cabin air. For the few times that I do, I can easily use the MFD.
    I was thinking that I could free up the recirc switch on the steering wheel to serve as a mute switch for the radio since there's the external volume control for the radio and I could just tap into that.
    But, after looking at the wiring diagrams, it looks like the recirc switch is not a simple on/off switch and is part of a more complex/combination switch for the air conditioner in general. But, what do I know, I can't read electrical plans... Is the latter true or can I tap into this and use this switch as a simple on/off for the volume control??
    Thanx,
    -bob
  2. jeepien
    jeepien Member
    165
    New Jersey
    To turn the radio off from the steering wheel, press the Mode switch and hold for two seconds.
  3. brosnan
    brosnan Member
    159
    Silicon Valley
    Re: Need someone with electrical knowledge to confirm this..
    The RECIRC switch is connected to the wire labelled AC1 which goes to center terminal block post 5B-14. When you press the RECIRC switch you'll find 2.57V on wire AC1 . When not pressing, you'll find 4.83V. However, 3 other switches share this line and use different series resistor values to get 3 other voltages (3.68V if you press "INFO", 1.06V if you press "DEF-REAR" and 0V if you press "DEF-FRONT"). So if you really want to avoid the 2 second delay of the MODE switch you could build a circuit which detects voltage near 2.57V and then mutes the audio, but it would be a lot of work.
  4. brosnan
    brosnan Member
    159
    Silicon Valley
    The white wire on the large connector on the NAV ECU is a mute output. There's probably a way to add a mute switch to pretend the NAV ECU just asked for the mute condition.
  5. bobc
    bobc New Member
    361
    Durham, NH
    Mike,
    Thanks for the reply and all the info! As I look at the diagram while reading your explanation, that all makes sense. I couldn't figure out how 6 controls could operate off of just 3 wires, but I can understand that it's done by changing the voltage...
    Yeah, it would be too much work to re-tool this...
    BTW, I don't have the NAV option..
    Thanks again,
    -bob
  6. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Yes, many of the controls are multiplexed by using a resistor network. Multistep digital, got to love it.
    Cruise control stalk also uses this arangement, making it harder for Coastal to develop their EV mod to use the cancel switch.
    Radio is a third.
