I'm looking for a source where I can find/obtain the sealed "pot box" that is part of the accellerator assembly. As far as I can tell it is not listed anyplace as a "user replaceable" part but it looks lilke it can be removed and replaced as long as you have some way to calibrate the foot-feed position against the resistance. Maybe someone that has contacts in Japan or reads the the mail here that is in Japan can be of help. (I suspect the foot feed and/or pot box it is made by a vendor and possibly supplied to Toyota as a complete assemby.) Thanks.
<div class='quotetop'>QUOTE(mehrenst @ May 14 2006, 10:16 PM) [snapback]255549[/snapback]</div> I understand that Hall effect sensors are used to determine pedal angle on NHW20 Prius - is this correct? But perhaps you have other plans for it. I've contact several dismantlers for the entire assembly, and have not yet found a source. Have you read my document on renovating it?
