Need source for new wheel
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dan1520, Aug 24, 2010.
  1. dan1520
    dan1520 Junior Member
    While exiting our bank's drive-thru I turned the wheel a bit too soon and the right rear wheel scraped the high curb rather hard. Ever since then, I've been losing air in that tire. I pulled the wheel and checked for leaks but found none. However, it loses air when I drive which causes me to think the wheel is the problem whereby it loses air when the car makes turns and the tire comes apart from the wheel. The proof of this was the car sat for two months and no air was lost. My questions are this;
    Is there another source for wheels other than the dealer? I suspect a junk yard is one source. Any other sources?
    What other Prius years will fit the car? Mine is a 2005.
    I check the spare but it's yellow and only good as a spare.
    Thanks
  2. Bob64
    1,540
    92
    Virginia
    Did you try finding the leak? Use soapy water and a sprayer. Pump your tire up to like 45 psi and then spray around the tire until you find bubbles.
    As for looking for a new wheel.... you can try ebay or steve at autobeyours.com (he salvages priuses)
  3. actros
    actros New Member
    16
    16
    Colorado
    2003 Prius
    Adopt a part in Denver has them.
    303 296 2211
    18005082211
    No sweat!
    Actros
