Need suspension diagrams for rubber lubrication
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Jul 21, 2018.
  1. icyrius
    icyrius Active Member
    233
    111
    Florida, USA
    2014 Prius v wagon
    My 2011 Gen 3's rear suspension sounds just like an old wooden rocking chair every time I get in and out of my car. I watched a couple of videos in YouTube and they showed this noise goes away by lubricating the rubber suspension components.
    Can anybody share the PDF sheet with the diagram showing the rear suspension assembly? This would save me some time when I look for them under the car.
    Thanks
  2. ChapmanF
    15,664
    Did the videos you saw show some method of lubricating the rubber parts short of disassembly? Mine sound the same way.
    -Chap
  3. icyrius
    233
    111
    Florida, USA
    2014 Prius v wagon
    One video showed lubricating a Toyota Camry suspension using a spray gun. The only disassembly done was removing the tires. The process seemed simple to do. I was hoping to have a diagram to find every rubber bushing needing lubrication.
  4. icyrius
    233
    111
    Florida, USA
    2014 Prius v wagon
    Well, I finally had the time to look for those rear bushings and to my surprise the Prius did not have a rear bar with bushings (similar to the videos in YouTube). It basically rests on the shock absorvers and springs.
    The noise suddenly went away now that it has been raining everyday. Not sure how the rain contributed to it, but rear suspension creaking is certainly not there anymore.
  5. ChapmanF
    15,664
    I would have guessed the two large bushings (48725 F and G) and maybe the smaller ones that are integral with the bottom ends of the shock absorbers (image from parts.toyota.com):
    But I wouldn't have guessed it'd be easy to lube those bushings without removing them, which is a boatload of work, and I think they're supposed to not be reused if removed....
    -Chap
  6. icyrius
    233
    111
    Florida, USA
    2014 Prius v wagon
    Thanks for the diagram. I will check again next weekend and post the findings.
