Need to buy brake Acuator
Discussion in 'Gen 2 Prius Main Forum' started by JLacy76, Sep 5, 2018.
  1. JLacy76
    JLacy76 Junior Member
    50
    West Palm Beach, Florida
    I found some on Ebay for about $250 shipped. Is there a better place to buy?
    DLC82SV likes this.
  2. kens97uber171
    kens97uber171 Active Member
    177
    132
    US
    Can also look at salvage yards.. I found one there for $250 also.
    Bear in mind always some risk with a used part... Could work fine and then fail as the original one in the car did.
    There are three different part numbers.. within 2004-2009. It's not depending on the year.. it's random. I guess.
    My experience has been it does not matter which one you buy they are all interchangeable... I'd go as new as possible however or lowest miles.. or both if possible.
    Granted mine is a sample of ONE..
    But Toyota said I had to have one part number .
    I used another and it worked just fine..
    Took me about 5 hrs to swap in the new one.
    If you need any tips let me know ... It was not too bad of a job.
    PriusCamper and DLC82SV like this.
  3. Lovemymia
    Lovemymia Junior Member
    Oregon
    @kens97uber171 My Prius was recently diagnosed with a $2,442.45 brake accuator replacement from Toyota. I have been reaserching forums for a DIY job and was hoping you could give me some guidance on tackling this bad boy. Anything would be greatly appreciated.
    You mentioned 3 different part numbers??
    Thank You in advance
    Sue
  4. Lovemymia
    Oregon
    Attached is a pic of how Toyota came to this conclusion and the cost of repair.
  5. DLC82SV
    DLC82SV Member
    241
    119
    Where is it at?
  6. Lovemymia
    Oregon
    Where is the car located? Salem, Oregon
  7. kens97uber171
    177
    132
    US
    Buried under the inverter against the firewall.
    There are a few videos on YouTube that can help.
    DLC82SV likes this.
  8. kens97uber171
    177
    132
    US
    DLC82SV likes this.
  9. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I could be wrong but what I read was they are not sure because you have a non Toyota battery with corrosion on the positive terminal. I would suggest cleaning the battery terminals first and then doing a voltage check on the 12v battery.
  10. DLC82SV
    DLC82SV Member
    241
    119
  11. ChapmanF
    15,571
    In the various TSBs available showing actuator replacement, you will usually be urged to have some small plastic baggies on hand, or the like, to secure immediately over those disconnected brake-line ends to prevent contaminants getting in (especially in an engine compartment with that much dust and dirt around). You may also be advised to avoid using any cloth rags or gloves that could shed small fibers into the lines or the actuator.
    (If installing a used actuator, you might also want to know whether the person pulling it followed those recommendations.)
    -Chap
