Need to Install Oil Catch Can - in Bay Area Help!
Discussion in 'Gen 3 Prius Technical Discussion' started by champion510, Sep 14, 2020.
  1. champion510
    champion510 Junior Member
    23
    Hi All,
    New 2014 prius owner with 20k miles on it. Bought it used.
    I want to install Oil Catch can and change my oil.
    Oil Catch can - I see several on amazon, not sure which one to get
    Oil Change and Filter - Thinking about Mobile 1 and OEM toyota filter
    Is there anyone in bay area that can help me do this? I'm not very mechanically inclined but I'm a quick learner if you can show me - Ideally you like working on cars and drinking beer (which I'll supply)
    Many Thanks
  2. wr69
    wr69 Member
    140
    77
    portland, or
    i wrote an OCC document and posted via my signature link. I'm not is SFO, but it has other good info in there - if you want to try DIY.
    SFO likes this.
  3. freebird1
    freebird1 Junior Member
    59
    Dallas, TX
    state emissions tests ?
    if they open hood and see occ they can fail car
    Or not an issue
    #3 freebird1, Nov 25, 2021
  4. wr69
    wr69 Member
    140
    77
    portland, or
    im not sure what every states laws are. but its still a closed system. i think i have read some CA folks state its okay in there state when they go in for an inspection. In Oregon, I dont know what happens either - but they usually just plug in computer (no engine bay inspection), and call it good (or bad), based on what the computer spits out. If you follow my steps - which are the same as many others who did the job - you are left with the u-shaped hose which can be put back on the car. My install just uses cable-ties too, which means removal is pretty easy. Lastly, if you are worried a great deal, some cans have the words "oil catch can" imprinted on the top. that is a dead giveaway. might want some more non-descriptive can. And use black fuel line tubing which blends in with every other black tube in the engine bay.
  5. Paul E. Highway
    Paul E. Highway Active Member
    200
    127
    Hawaii
    -Mobil One and OEM filter are a good choice
    -I cut the U shaped hose in half, swiveled each side down, and ran them to my OCC mounted below the air box via a Moroso bracket on frame. Easy to check at oil change time.
    -it’s invisible from top but here they just plug in OBD and check for codes.
  6. Mendel Leisk
    38,644
    There’s an oil catch can thread* linked in my signature.
    * the @danlatu thread, a biggie
    see initial post was over a year ago lol.
