Need to open hood from outside?
Discussion in 'Gen 2 Prius Main Forum' started by Road Fan, Dec 20, 2021.
  1. Road Fan
    Road Fan One-Prius,one Audi,7-bike Family
    45
    Ann Arbor, MI
    Four Touring
    2009 gen 2 Touring 4, no response to key fobs, so the car appears to need a jump, and the car has been sitting about three weeks. Not sure if it matters, but the center stack display has been out since the summer (it’s hard to find the right head unit). Normally I’d use the valet key to access the hood lever, but while it fits the lock it will not turn. Will spray/inject some Lock-ease and see if I can enter and open the hood. My guess is the 12v battery is discharged, and needs some driving or replacement. But what do the experts think?
    if I could get some voltage on the 12 volt battery maybe the entry systems will wake up, let me get in, and try an engine start.
    Ann Arbor, MI
  2. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
  3. Road Fan
    45
    Ann Arbor, MI
    Four Touring
    Ok thanks! So one can’t trip the hood latch mechanically from the outside?
    If that’s the case, then the way T intended this to be solved is via the door locks (as an alternative to getting a new car).
    51,154
    i would really work that lock, and even consider a locksmith. i think you can access the hood by removing the front bumper, which seems like a lot of work.
  5. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    #5 alftoy, Dec 20, 2021
  6. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Be careful using an air wedge, it is very easy to wedge the door a bit too much which will cause a permanent gap for the water to leak in.
    Best to just use AAA at this point, which gets you a jump start, and a mechanical key or vehicle entry.
  7. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    If you can find a similar Prius to study you might somehow be able to find a way to pull on the hood cable that releases the latch...
  8. Another
    1,818
    515
    Naples, Florida
    Go to parking lot and practice on other people’s locked car?
  9. alftoy
    1,132
    514
    Parking lot? Nah, go to YouTube and find a similar Prius. Then practice on yours.
  10. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Do what is above in YouTube. My latch broke and my mechanic (actually located in Ann Arbor) did it for me and put a zip tie hanging out the front, attached to the latch that I now use to open hood lol. It's rigged but it has 285k miles.
    If you can't figure it out he is located Jackson/94 area.
    SFO likes this.
  11. PriusCamper
    12,064
    4,896
    You need someone who can pop there hood for you so you can see if there's a way to make a tool to pull your hood release... Every car has a different set of challenges but when I worked in an auto shop long ago a busted cable like this was a relatively common challenge. I even had to figure it out on my Subaru back in early 2000's.
