Need to replace front passenger door speaker 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, Mar 11, 2023.
  1. GreenTea&SaltWater
    198
    58
    Los angeles
    The speaker blew out, one on the door near the floor. Is this a woofer? What should I look for when shopping for a new speaker, what will fit? And do you have any recommendations under $100? I'm a music enthusiast so something that sounds decent but still affordable.
  2. Tombukt2
    Tombukt2 Senior Member
    12,215
    2,155
    Durham NC
    Look on crutchfield for fit info. In my older Prius I've 6.5 infinity branded. Mid drivers the fit right in. I drilled out old riveted in drivers bought the Prius door spacers and used screws to mount. Didn't have a rivet gun at the time or I couldn't find it so I just use sheet metal screws with zip tape in between the spacer and the screws to help with some vibration and they're still in place working well full rubber surrounds and all.
  3. Mendel Leisk
    40,586
    The Toyota spec speakers are shown here:
    SPEAKER. 2010 Toyota Prius Base | Toyota Parts Center Online
    I'd speculate with your 2010 being level "one", it'd be the third option, part number:
    86160-47070
    But you should verify by looking at what you've got.
    Note: there's "suggested retail" price, but if you click on specific dealership links, you'll see their "street" price, typically lower.
    As far as your speculation that it's a woofer, it's gonna be a full range speaker, possibly coaxial.
    https://en.wikipedia.org/wiki/Coaxial_loudspeaker
    GreenTea&SaltWater likes this.
  4. GreenTea&SaltWater
    198
    58
    Los angeles
    so 6.5 and 6x9in fit is what it looks like right?
    Tombukt2 likes this.
  5. GreenTea&SaltWater
    198
    58
    Los angeles
    thank you i'll shop for full range then
  6. Mendel Leisk
    40,586
    The part no I posted above may be just a "tweeter", indicated thus here:
    https://www.ebay.com/itm/124955594636
    The other two options (in previous link) are more likely then. If you're just replacing the failed one, for sure pull it out first and look for it's part number, hopefully it's marked. To ensure the two fronts match.
  7. Tombukt2
    12,215
    2,155
    Durham NC
    This is why I use crutchfield right regularly to quickly look up without taking all my panels off as I was just replacing the front door speakers in my '09 Prius or it might have been an '07 and the Infinity mid base drivers were the perfect match as far as I was concerned to put there and to do that you buy these plastic spacers that you can get at Walmart or online and you offer that up to the door and you see what you have to do to make it go there and then pop your door panel back on that takes care of that If there are six by nines anywhere in the car the crutchfield site will tell you where they are I just did my front doors and I also replaced the tweeters and their respective places on the other side of the side mirrors with silk dome something another's.
