Need to replace USB / Aux sockets in Prius 2011
Discussion in 'Gen 3 Prius Audio and Electronics' started by S Srivastav, Aug 25, 2013.
  1. S Srivastav
    S Srivastav New Member
    A plastic USB stick broke in the USB socket and now I cannot get it out. How hard would it be to replace that whole USB/Aux socket unit located in the center compartment (between the 2 front seats)?
    Can I order the part? Would a local car stereo shop be able to do the repair?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    If you can get the assembly out of there, it might be easier to remove the broken part from the socket. A pair of tweezers might be the right tool. The assembly itself should be readily available at your dealer.
  3. S Srivastav
    I've tried nose pliers. No luck. Will call the dealer to see if they have the USB/Aux connector available.
