Negitive Battery cable turning black in HV battery pack
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Sep 17, 2013.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I saved a 2005 from the repo yard, it had been sitting about a year so I got it at a good price, I got her going but the dash had the red triangle so I pulled the battery pack..all the cells but one tested between 7.6 and 7.8, one was 6.54 so I replaced it and it seems to be running OK now, no warning lights on the dash...all the negitive terminals have a lot of corosion on them that I cleaned off and the thick negtive cable is black on the ends....Im guessing Ill need a new harness soon or is this normal?
    Thanks :cool:
  2. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    Cleaning them in a mild acid solution such as vinegar or phosphoric acid (alloy wheel cleaner) the same for the terminals reassemble and apply a thin coat of sealer.
    John (Britprius)
