Nema 14-50 Plug
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by heather somaini, Jan 17, 2013.
  1. heather somaini
    heather somaini Junior Member
    76
    Los Angeles, California
    If there is a 240v 40A Nema 14-50 plug in my building, can I just get an adapter for the cable that came with the Prius Plug-in and plug it in? Or will it blow up my car? :)
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    DO NOT run anything above 120 volts into the non-upgraded L1 EVSE that came w/your car. You will blow it.
    If you want to run 208+ volts into it, get it upgraded by EVSE Upgrade - Products (run by pEEF here aka Ingineer on mynissanleaf.com).
    At a meeting a little over a year ago at the Googleplex (which I was at) w/the Leaf's Chief Vehicle Engineer, Mark Perry of Nissan, some other senior Nissan folks and Nissan engineers from Japan, their quality guy brought up people blowing their L1 EVSE by running 240 volts into them via adapters of some sort. Recent posts on this at My Nissan Leaf Forum • View topic - EVSE Upgrade.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    mxben likes this.
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Log In | Facebook has an example of a Nissan L1 EVSE (also made by Panasonic, like Toyota's) fried by running it at above 120 volts.
  5. heather somaini
    76
    Got it thanks!!!! I thought so but wanted confirmation. :)
  6. lensovet
    2,614
    496
    Burlington, NJ
  7. bisco
    49,409
    and if you get the upgrade, you can then use it for 240v or 120v.
  8. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    DadofHedgehog likes this.
