Neutral message
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by janet1212, Nov 16, 2020.
  1. janet1212
    janet1212 New Member
    Illinois
    This morning, I started the Prius. Put it in reverse to drive out of garage. When I put in drive this message came up.
    Batteries will not charge when neutral.
    Tried three times to put Prius in drive by restarting the car but each time this message appears.
    Any ideas what is up?
    Prius is a 2008.
  2. PriusCamper
    PriusCamper Senior Member
    11,095
    4,515
    Pacific Northwest, USA
    Do you have any warning lights? If so reading the error codes will help... Or if you can't easily do that right now try disconnecting the 12v battery for 5 minutes and see if that helps?
    #2 PriusCamper, Nov 16, 2020
    janet1212 likes this.
  3. Moving Right Along
    Moving Right Along Senior Member
    690
    540
    Did you have the door open a little? That happened with me when I didn’t fully shut the door, which prevented the car from going into drive. Opened and shut the door firmly, and that took care of it.
    runxctry likes this.
  4. janet1212
    Illinois
    No door not open. But may not have closed it properly
  5. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    This. This is the notice anytime a door is open while in gear. It's not exactly self-explanatory, unfortunately.
  6. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    If the door is not closed properly, is it not therefore open?
