"Neutral" What is it?
Discussion in 'Gen 3 Prius Technical Discussion' started by OZ132, Sep 15, 2009.
  1. OZ132
    OZ132 Member
    170
    Northern Indiana
    Not like neutral in a car with a "Transmission."
    So, how does it work?
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Turn off the switch on the wall to your TV.
    The power station still has power, the TV isn't broken but there is no picture and sound. That is how neutral works in a Prius.
    All it does is switch off the power to MG1 & MG2. They can neither capture or release kinetic energy.
  3. PaulHS
    PaulHS Member
    200
    SE PA
    Pat, this is a great, concise explanation. Nicely done!
  4. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    Note that this implies some things. For example, if you push or pull a Prius in "N" too fast you can generate pretty high voltages inside the MGs (no load) as well as the inverter. There are warnings in the owners manual about that.
    Also, like many other cars, parts don't get properly oiled unless the system is running, so a -short- tow will be ok, but don't expect to tow a long distance without damage! Most of the parts in the HSD will be spinning when you tow it. The engine won't spin.
    So, for example, if you want to tow behind your motor home, front wheels off the ground please! Or better yet, perhaps a trailer.
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Both MG1 and MG2 are connected through six each IGBT's(switching devices).
    As Pat wrote, all IGBT's are off during N position.
    Ken@Japan
  6. nparker13
    nparker13 Member
    121
    CT
    Who has a wall switch for their TV?
  7. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Aussies, apparently.
    And . . . folks who want to be able to cut off all electric flow to electronic devices in order to save $$ and lower pollution.
  8. BlueIce
    BlueIce New Member
    43
    Plymouth, Wi
    I do. Check the standby wattage on the TV nameplate, You will want to add a switch. Its called phatom power your computer, printer, phone chargers etc... all use power if not unplugged or switched off by a wall switch. Added all the watts you maybe surpise how much power to being used for nothing.
  9. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    FYI, when in Neutral, the throttle is also disabled.
    David (aka Blind Guy)
  10. kingkongva
    kingkongva Junior Member
    virginia
    can u glide in neutral? is it safe to do so?
    thx
  11. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    kingkongva,
    If it hasn't been said, :welcome: to PRIUSchat.
    Yes.
    A qualified yes, up to 60 MPH anyway. There are other safety considerations:
    no regen braking if needed, etc.
    These answers are for the Gen II, if not applicable to Gen III, I trust that I'll
    be corrected.
    Here's a good thread for more info:
    http://priuschat.com/forums/gen-ii-...parison-methods-pedal-control-vs-neutral.html
  12. patsparks
    10,664
    567
    All power points in Australia have a switch.
  13. patsparks
    10,664
    567
    60mph?
    I won't glide in neutral over 64km/h The ice will spin if the speed is over 64km/h if the transmission is in drive so I won't go over 64km/h in neutral, which I do use sometimes on long gentle hills where the speed holds pretty true. I pop the trans into drive to wash off speed if it goes over 64km/h.
  14. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Pat,
    Yes, 60 MPH as discussed in this thread, which for new folks may be
    more accessible that the one I cited earlier:
    http://priuschat.com/forums/gen-ii-prius-main-forum/38676-coasting-in-neutral.html
    As I understand it, 60 MPH is the theoretical speed maximum safe
    speed. I would never push things like this to the limit, but at least two
    posters have reported going over it for a very short period without
    apparent damage or ill effects.
    Not me, brother. ~ 35 MPH is the highest I've gone. That's about what
    62km/h? We would seem to be of one mind on this.
    A speculation, perhaps even somewhat informed :rolleyes: : I strongly suspect that
    somewhere in the HSD there is a logging function that logs the highest
    values for critical operational functions; max temps for ICE, MGs, HV batt,
    etc; ICE rpms, speed, etc. I think that max MG1 rpms is one of the values
    recorded and therefore retrievable by techs. An overspeed would likely
    cause subsequent trouble in a warranty claim on drive train components.
  15. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    There are two conditions about "shifting to neutral" above 42mph.
    http://priuschat.com/forums/gen-ii-prius-main-forum/38676-coasting-in-neutral.html#post504027
    "4) Above 42 MPH the ICE always runs. If you select N above 42 MPH then the ICE runs by burning fuel. If you feather the pedal and obtain warp stealth, then the engine spins but the engine does not use any fuel. If you go to N above 42 MPH the ICE uses fuel to idle.
    5) Warp N This is where you select N below 42 MPH with the ICE off and then go faster than 42 MPH. The ICE will not come on because the electric motors will not engage. This mode is not recommended because you can overspeed MG1.
    Pat is saying about the condition (4).
    I think you're saying about the condition (5).
    Please be aware that the lubricating oil pump for the PSD is driven by the ICE, therefore it is not good idea to let the ICE off for long distance at high speed.
    Ken@Japan
  16. OZ132
    OZ132 Member
    170
    Northern Indiana
    Thanks, guys! And "Park"? That adds a mechanical pawl to keep th car from moving?
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Correct. Park is different from Neutral in two ways:
    1) A mechanical parking pawl keeps the drive wheels from turning.
    2) The ICE can start and charge the battery while in Park.
    Tom
  18. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    The mechanical pawl is the reason you should probably engage the parking brake if parking on much of an incline. Sorry, just can't think of the thing as an "emergency brake"
  19. qbee42
    18,058
    3,073
    Northern Michigan
    Are you refuting a previous posting, or is this just a random comment?
    Tom
  20. a64pilot
    771
    62
    Albany Ga.
    I couldn't point as to which posting, but I have seen it called an emergency brake. I assume that was just a mis-naming though.
